Stator cover
- ricerocket
Stator cover
04 Sep 2007 13:33
I have a small oil leak only when the bike is hot.It seems to be around the front of the stator cover lower area.i cannot seem to locate it I noticed the previous owner instead of a real gasket he used some blue type gasket maker.So my question is there any oil where the staor cover is ?Inside it i mean.
- RonKZ650
Re: Stator cover
04 Sep 2007 14:46
If you take off the stator cover there will always be some oil in there. Can vary from just a little to several ounces. I was never 100% sure if the oil was meant to be there or not. Some guys here have said it aids in cooling the stator. Whether that is true or not I don't know, but you should use a real gasket on the cover.
- iandz500
Re: Stator cover
04 Sep 2007 15:29
i know on my modern yamaha the oil has to be drained before the stator cover is removed. not sure about old kwaks though, mind you if its leaking i'd say you should try to get the proper gasket for it!
Bikes: 1960 lambretta Li125 sold; 2001 Honda CG125 sold; 2006 Yamaha FZ6 sold; 1980 Kawasaki Z500 sold; 1967 BSA Bantam D10; 2008 Aprilia Shiver sold; 2010 KTM Duke 690R; 1954 BSA Bantam; 1980ish Kawasaki Z200
- donthekawguy
Re: Stator cover
05 Sep 2007 02:51
There is oil in it so don't worry about that. You should replace the gasket and check the gromet for the stator wires because those seem to leak a lot.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Bluemeanie
Re: Stator cover
05 Sep 2007 05:22
Not trying to change thread just curious, stator cover off my 650, bone dry! 900's/1000's supposed to be wet?
- RonKZ650
Re: Stator cover
05 Sep 2007 06:42
Bluemeanie wrote:
That kind of coincides with what I always thought. I really don't think by design oil is supposed to be in there, but some eventually leaks past the seals ect, and is trapped in there with nowhere to go unless it happens to leak. That was always what I thought. Other guys thought the oil cooling of the stator thing.Not trying to change thread just curious, stator cover off my 650, bone dry! 900's/1000's supposed to be wet?
