I am confused about top-dead-center
- Ray J
I know this is a basic question, so be gentle. I know the piston is at the top at TDC. I would think the cam lobes would be in line with the pistons. Thanks.
- APE Jay
- Banned
- Thank you received: 58
Jay
- jjdwoodman
- Live free, or die.
- Thank you received: 1
Wish I knew how to draw on this contraption, but if you rotate the engine over by hand you'll get the drift I'm sure.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
- 79MKII
- Love Them Kaws!
- Thank you received: 43
The strange thing is the cams only rotate at 1/2 the speed of the crank, so it takes 2 crank revolutions for one cam revolution. For example, you can be at the T mark for 1-4 and the #4 cylinder cam lobes will be facing each other and then the next time you're at the 1-4 T mark, they will be pointing away from each other :S That one took some getting used to for me!!
The Kaw List:
- Ray J
You've succeeded in clearing a little more of the fog in my brain.
- steell
Ok, now I get it. I was also wondering about why the 1 and 4 lobes (and the 2 and 3) were not lined up, so thanks for answering that 79.
Now that would be interesting, make a four cylinder KZ cam with the 1 & 4 and 2 & 3 cam lobes lined up so 1 & 4 fire as one and 2 & 3 fire as one, that would give you one strong power pulse per revolution, kind of like a four cylinder two cylinder
Bet it would have a unique exhaust sound
Might be hard on the crank though.
I seem to recall that Yamaha (and maybe others) did that on some racing bikes.
Post edited by: steell, at: 2007/09/03 10:53
- loudhvx
- Thank you received: 1616
Post edited by: loudhvx, at: 2007/09/03 11:20
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 76 LTD
- Thank you received: 2098
