Varying Valve Clearance?????
- cgray34
27 Aug 2007 18:28 #166739
by cgray34
Varying Valve Clearance????? was created by cgray34
I have a varying valve clearances across the board.
INTAKE
EXHAUST
1. .003 .0025 INCHES
2. .0025 .002
3. .002 .0025
4. .0025 .004
QUESTIONS:
1. What does this mean?
2. Can I shim each one with a different size to make them all the same? Do I want them all to be the same?
3. Is it possible this is worn down lobes?
4. How will this effect performance?
INTAKE
EXHAUST
2. .0025 .002
3. .002 .0025
4. .0025 .004
QUESTIONS:
- cgray34
27 Aug 2007 18:30 #166741
by cgray34
Replied by cgray34 on topic Varying Valve Clearance?????
Sorry for the lack of spacing.
INTAKE
EXHAUST
1.--- .003
.0025 INCHES
2. ---.0025
.002
3. ---.002
.0025
4. ---.0025
.004
QUESTIONS:
INTAKE
EXHAUST
1.--- .003
.0025 INCHES
2. ---.0025
.002
3. ---.002
.0025
4. ---.0025
.004
QUESTIONS:
- RonKZ650
- Thank you received: 240
27 Aug 2007 18:39 #166747
by RonKZ650
Replied by RonKZ650 on topic Varying Valve Clearance?????
Those clearances are OK really, but on the tight side. I'd swap the 7 tight ones with a shim 1 size smaller than what you have now, then you'd be close to .004" on them all. I doubt seriously you'll tell any difference in performance whether you swap them or not.
- mark1122
- Keep twisting it
- Thank you received: 109
27 Aug 2007 19:08 #166758
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Varying Valve Clearance?????
your in good shape this is norrmal. the gap gets smaller as things ware so next year when u reshim u can go to the top end of the spec..004"
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
