Clutch slippage
- SuperTrey
27 Aug 2007 05:47 #166582
by SuperTrey
Clutch slippage was created by SuperTrey
Under heavy throttle i have experienced what i think is clutch slippage around 6 or 7 thousand rpm. It feels like i have pulled the cluth in about halfway, the motor revs higher then "catches" again and continues accelerating.
What could cause this? Bad clutch?
it is on my 78 kz1000 A2
- 810gpz750
27 Aug 2007 07:51 #166601
by 810gpz750
Replied by 810gpz750 on topic Clutch slippage
had the same problem on my gpz750 but at about 8k to 10k replaced my springs with the red ones from parts unlimited. no problems since then. try springs first i was fully prepared to throw in a clutch pack when my mech took a look and said all was good.
- Thank you received: 2098
27 Aug 2007 09:12 #166613
by Patton
Replied by Patton on topic Clutch slippage
If not already done, would first adjust required slack in the clutch push rod.
Am presuming there's already a little slack in the clutch cable at the handlebar end when the lever is not being squeezed.
Maladjustment in either of the above could prevent the clutch from fully engaging and thereby cause it to slip (especially under heavy load).
Good luck with the repairs.
Post edited by: Patton, at: 2007/08/27 12:13
- coppertales
27 Aug 2007 12:18 #166660
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Clutch slippage
Change your clutch cable first. It may be frayed inside the housing causing the clutch not to release properly.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- SuperTrey
27 Aug 2007 14:26 #166683
by SuperTrey
Replied by SuperTrey on topic Clutch slippage
I have a new cable so i will check the rod. beyond that, i will try the springs.
If i was to put in a whole new clutch, what parts are involved in that?
- KaZooCruiser
- Thank you received: 7
27 Aug 2007 15:03 #166691
by KaZooCruiser
Replied by KaZooCruiser on topic Clutch slippage
How many miles on the bike?
Maybe you need to try a different oil. Additives can cause the clutch to slip.
You also might be able to scuff up the plates to clean off any glaze that might be on them.
- SuperTrey
27 Aug 2007 15:04 #166693
by SuperTrey
48,000 miles, I currently am running 10w40 w/ 1 quart of lucas oil to help with oil consumption.
suggestions?
suggestions?
- KaZooCruiser
27 Aug 2007 15:10 #166695
by KaZooCruiser
1. Quit using the Lucas.
2. Do an oil and filter change to get it out of the transmission before it glazes the plates.
3. Do another oil change in 500 miles.
- Mellvis
- Thank you received: 3
27 Aug 2007 18:11 #166737
by Mellvis
Replied by Mellvis on topic Clutch slippage
All of the old Kaws I've messed with had weak factory clutch springs. I think it was a warrenty gag. A clutch was easier/cheaper for a dealer to replace under warrenty than a transmition and some slippage would keep people from tearing stuff up. On all of my 650s, I replaced the factory springs with 900 inner valve springs. Works great!
- redrkt
- Thank you received: 1
27 Aug 2007 18:47 #166752
by redrkt
Replied by redrkt on topic Clutch slippage
I had the same problem with my GPz750 ('82). I stopped using synthetic oil, went back to the standard 10W-40 oil (changing every 2 or 3K miles) and haven't had a problem with the clutch since. At some point, I will replace the clutch plate and springs, but not yet!
- SuperTrey
28 Aug 2007 13:05 #166916
by SuperTrey
So the Lucas oil additive is too slippery and may cause failure of the clutch?
Is there some other additive that would help with slight oil consumption or am i wasting my money?
- KaZooCruiser
29 Aug 2007 16:36 #167195
by KaZooCruiser
You have a 30 year-old, 48k mile motor, which is air cooled.
About like mine.
Lucas may be fine for motors alone, but because it is a friction reducer, is probably not a really good additive where a clutch friction discs are concerned.
Oil consumption, what to do. . .
Replace the valve stem seals. They are probably worthless as far as oil control if they are original.
Rering the motor. The compression rings are probably ok, but the oil rings are pretty anemic as far as tension, even when new.
Sometimes knurling the piston skirts can help a bit with oil control.
Use 15w-40.
Or maybe a 20w-50.
About like mine.
Use 15w-40.
Or maybe a 20w-50.
