Clutch slippage
- SuperTrey
Clutch slippage
27 Aug 2007 05:47
Under heavy throttle i have experienced what i think is clutch slippage around 6 or 7 thousand rpm. It feels like i have pulled the cluth in about halfway, the motor revs higher then "catches" again and continues accelerating.
What could cause this? Bad clutch?
it is on my 78 kz1000 A2
- 810gpz750
Re: Clutch slippage
27 Aug 2007 07:51
had the same problem on my gpz750 but at about 8k to 10k replaced my springs with the red ones from parts unlimited. no problems since then. try springs first i was fully prepared to throw in a clutch pack when my mech took a look and said all was good.
Re: Clutch slippage
27 Aug 2007 09:12
If not already done, would first adjust required slack in the clutch push rod.
Am presuming there's already a little slack in the clutch cable at the handlebar end when the lever is not being squeezed.
Maladjustment in either of the above could prevent the clutch from fully engaging and thereby cause it to slip (especially under heavy load).
Good luck with the repairs.
Post edited by: Patton, at: 2007/08/27 12:13
- coppertales
Re: Clutch slippage
27 Aug 2007 12:18
Change your clutch cable first. It may be frayed inside the housing causing the clutch not to release properly.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- SuperTrey
Re: Clutch slippage
27 Aug 2007 14:26
I have a new cable so i will check the rod. beyond that, i will try the springs.
If i was to put in a whole new clutch, what parts are involved in that?
- KaZooCruiser
Re: Clutch slippage
27 Aug 2007 15:03
How many miles on the bike?
Maybe you need to try a different oil. Additives can cause the clutch to slip.
You also might be able to scuff up the plates to clean off any glaze that might be on them.
- SuperTrey
Re: Clutch slippage
27 Aug 2007 15:04
48,000 miles, I currently am running 10w40 w/ 1 quart of lucas oil to help with oil consumption.
suggestions?
suggestions?
- KaZooCruiser
Re: Clutch slippage
27 Aug 2007 15:10
1. Quit using the Lucas.
2. Do an oil and filter change to get it out of the transmission before it glazes the plates.
3. Do another oil change in 500 miles.
- Mellvis
Re: Clutch slippage
27 Aug 2007 18:11
All of the old Kaws I've messed with had weak factory clutch springs. I think it was a warrenty gag. A clutch was easier/cheaper for a dealer to replace under warrenty than a transmition and some slippage would keep people from tearing stuff up. On all of my 650s, I replaced the factory springs with 900 inner valve springs. Works great!
- redrkt
Re: Clutch slippage
27 Aug 2007 18:47
I had the same problem with my GPz750 ('82). I stopped using synthetic oil, went back to the standard 10W-40 oil (changing every 2 or 3K miles) and haven't had a problem with the clutch since. At some point, I will replace the clutch plate and springs, but not yet!
- SuperTrey
Re: Clutch slippage
28 Aug 2007 13:05
So the Lucas oil additive is too slippery and may cause failure of the clutch?
Is there some other additive that would help with slight oil consumption or am i wasting my money?
- KaZooCruiser
Re: Clutch slippage
29 Aug 2007 16:36
You have a 30 year-old, 48k mile motor, which is air cooled.
About like mine.
Lucas may be fine for motors alone, but because it is a friction reducer, is probably not a really good additive where a clutch friction discs are concerned.
Oil consumption, what to do. . .
Replace the valve stem seals. They are probably worthless as far as oil control if they are original.
Rering the motor. The compression rings are probably ok, but the oil rings are pretty anemic as far as tension, even when new.
Sometimes knurling the piston skirts can help a bit with oil control.
Use 15w-40.
Or maybe a 20w-50.
About like mine.
Use 15w-40.
Or maybe a 20w-50.
