trouble getting 82 kz650 csr to warm up
  • Progpunk76
  • Progpunk76's Avatar Topic Author
26 Aug 2007 16:33
#166462
My 82 kz650 csr takes forever to warm up. Just had carbs cleaned (it wasn't runnin before that). When i start it with the choke on full it will start reving high in about a minute. Then I'll have it half out and it will warm up more and start reving really high in about two minutes. So i'll put it all the way in to start riding and it will stall. To ride it, i'll have to still have the throttle turned a bit to keep it going at red lights or it will stall.Don't know if it's just cause it's old or what but it takes about 20 minutes to warm up enough to not stall anymore. And i can't ride it with the choke out half way because it revs at 8000 rpm if i have the clutch in at stop lights etc. Any help or advice is much appreciated.
  • BSKZ650
  • BSKZ650's Avatar
Re: trouble getting 82 kz650 csr to warm up
26 Aug 2007 17:46
#166473
sounds like you may have a couple of things going on, 1 a vacum leak 2 the carbs are still not cleaned well enough, also the carbs may not be adj correctly
77 ltd1000, current rider
76 kz900, just waiting
  • coppertales
  • coppertales's Avatar
27 Aug 2007 12:20
#166661
Ditto the above post........chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • kzwolfsr
  • kzwolfsr's Avatar
27 Aug 2007 17:49
#166733
I have the same problem! Does yours spit through the carbs?
Original man of the Caribbean
  • Progpunk76
27 Aug 2007 19:38
#166768
I don't know if it does or not. Have only been riding for 1 and a 1/2 years. Just got this bike, it didn't run but the thing was in mint condition so took a risk,bought it for $1000, got the carb cleaned and it worked! It's just now I'm having this problem. When it does warm up it runs perfectly. Once it sits for a half an hour, have to warm it up all over again. Really frustrating.:angry:
  • Progpunk76
30 Aug 2007 18:25
#167462
Actually the carb is spitting alot while it warms up, even when it gets warmed up it still does a bit. A friend and I took off the carb to get it cleaned and put it back on ourselves. We are still kind of beginners so we probably did'nt adjust it properly or something.Gonna take it in to a pro. Thanks for the advice guys.
30 Aug 2007 19:48
#167475
The particular pro may be the best ever, but hope you're not taking and relying on only his word for it. But please forgive my skepticism based on hearing way too many horror stories resulting from the supposed pro. There are some old-timer dealers and techs qualifying as pro, but there are many who do not so qualify and will blow smoke aplenty and cause you grief.
Best of Luck! :)
  • trippivot
  • trippivot's Avatar
31 Aug 2007 04:57
#167509
your carbs still need to be cleaned and tuned
properly
  • wiredgeorge
  • wiredgeorge's Avatar
31 Aug 2007 06:53
#167535
The pilot and choke circuits were not adequately cleaned. Also, you didn't mention whether you had a stock airbox or not but if you have pods on the bike, the pilot jets are likely too small... Your starting sequence is pretty normal but your bike is way too lean for too long. This COULD be from an air leak, as has been noted but I wouldn't expect the problem to go away if it were an air leak but to persist no matter how long your rode it.
  • Progpunk76
31 Aug 2007 14:24
#167602
I'm starting to think for sure that the carb probably needs to get tuned up, becauce we just put it on our selves after we got it cleaned at our local Kawasaki dealer here in Vancouver Canada. It ran perfectly for the first week and then that started happening.Think I'll take it back to Kawi so they can do it properly.
