I am preparing to replace the shifter, output, and clutch shaft oil seals in the left side mission cover on 78 KZ 650. It seems straight forward but not sure if the outer edge of the seals should be coated with a thin film of perma-tex or spray gasket type material or go in dry. Also, is there a preferred tool or method for "setting" the seals?
Thanks for your input.
