petcock positions for 1978 KZ400
  • primemover
  • primemover's Avatar Topic Author
07 Jan 2006 16:09
#16567
Hi Guys....
i was working on that KZ400 (1978) a little today (picked it up from a friend... needs LOTS of work!)...
anyway, the petcock has three positions:
On
Res
Pri
when i turned it to "Pri" gas started flowing out a bottom tube...
is that right?
i took the oppurtunity to drain the tank (which i wanted to do anyway)....
does this type of petcock have an
OFF position?
thanks...
- prime
  • OKC_Kent
  • OKC_Kent's Avatar
Re: petcock positions for 1978 KZ400
07 Jan 2006 19:18
#16604
Yes, it is right. What you have is a vacuum operated petcock. The prime position will always flow fuel.
The ON position only flows when there is a vacuum from a running engine, the RES position acts the same.
Use PRI to fill the carb bowls, then switch to ON. Don't leave it on PRI if the bike isn't running.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
  • primemover
08 Jan 2006 07:35
#16684
thanks!
so, there is then no way to take off tank unless it is emptied???
or would the "on" position (or "res") be ok (i.e., no vacuum, no flow?)...
  • OKC_Kent
  • OKC_Kent's Avatar
08 Jan 2006 13:10
#16741
Use the on position
Oklahoma City, OK
  • primemover
08 Jan 2006 17:42
#16784
thanks....
just sounds SO WRONG to use "on" for "off"!
but i do understand whay....
- prime
