Oil seperator 1978 KZ650 - leaking badly
- jdornski
- 1978 KZ650B2, 1972 H2, 1974 CB500(oops)
21 Aug 2007 19:43
Hi:
I rescued a 1978 KZ650. It was sitting for 5 years. On top of the crankcase is a round cover disk with a centre bolt and a vent for a tube. I am pretty sure there should be a tube from this vent to the airbox. The bike came without an airbox or this tube. I removed the 4 K&N air filters and fitted a used airbox.
My dealer says that the round disk covers the "oil seperator". When I ride, I am losing oil out of the vent, which is going all over the carbs and the airbox.
I removed the round cover disk and it just seems to cover an empty chamber about the size of a hockey puck. Is there supposed to be anything in the empty chamber like a screen or a filter?
I am reluctant just to add the tube to the airbox as it is likely just going to fill the airbox with oil.
The dealer suggested adding an external breather, but I do not think there is enough room to do this.
Thanks
jdornski
Thanks
jdornski
1978 KZ650B2, 1972 H2, 1974 CB500, 1972 XJ650, 1984 Honda Aero 80, 1933 AJS 350 Big Port(part-owner)
,johndorn@shaw.ca
250-404-0318
,johndorn@shaw.ca
250-404-0318
- The Milkman
Re: Oil seperator 1978 KZ650 - leaking badly
21 Aug 2007 20:11
There isn't anything underneath the cover but what you see. That is a breather for the engine. Is the oil too full, that would cause oil to be pumped out the hole. What you can do is add a lenghth of hose on it and cable tie it to the frame rail so just the fumes make it out the end of the hose and blow out. You may be getting too much blow by also, if you hold your finger over the hole in the cover for a few seconds with the bike running and take it off you will get a little pressure release but there shouldn't be a "LOT".
Ride safe.
Post edited by: The Milkman, at: 2007/08/21 23:11
Ride safe.
- jdornski
22 Aug 2007 21:04
Hi:
Oil is too full I think. The sidestand is bent and the bike sits at too much of an angle and the I over filled as a result. It is pretty difficult to see through an oil level window that is 30 years old. I will try the tube trick.
I assume there is supposed to be a tube from the oil seperator to the air box?
Thanks for the quick reply.
John
John
,johndorn@shaw.ca
250-404-0318
,johndorn@shaw.ca
250-404-0318
- BSKZ650
23 Aug 2007 05:05
with the stock air box the tube went to the bottom of it, a short hose and a filter on it to keep dirt out will work just fine
77 ltd1000, current rider
76 kz900, just waiting
- flht1997
23 Aug 2007 06:04
pretty sure you check the oil with the bike vertical. if you fill the window up with the bike on the side stand you are going to be way overfull.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
23 Aug 2007 18:58
Definitely put the bike on the centerstand when you check, change, or top off the oil. If the centerstand is missing have someone hold the bike upright. Also, I have found that after I change my oil I must check the oil level a couple times after letting the bike idle because the oil level changes (I suppose as oil is circulated through the system). Be careful not to fill to the top of the sight glass or you may end up with too much. Fill about halfway up the glass then run the engine at idle to warm it up a bit, shut off, and let sit for 10 or 20 minutes; then re-check. Ed
23 Aug 2007 19:02
23 Aug 2007 19:31
If not already done, would change the oil and filter.
Would also check the old oil for any gasoline odor which could indicate fuel intrusion into the crankcase via obstructed carb overflows (might explain oil level being too high).
And of course keep a close eye on the oil level.
