clutch not fully releasing
- bubba_d
20 Aug 2007 23:33
changed stock bars to superbike bars and now having hard time getting clutch to release fully. adjusted everything i could. think ill put a shorter cable on it. anky ideas?
1977 kz1000.
- tjettim
Re: clutch not fully releasing
21 Aug 2007 06:16
One of your cable connectors may of popped
out of its socket.Check the one halfway down
next to the front frame down tube.Check for
kinks or binding areas.Unless adjusted wrong,
or above problems it should work as before the
bar change.
bar change.
- bubba_d
21 Aug 2007 18:35
now able to fully release however it grabs almost all the way out. checked entire cable. no kinks.
1977 kz1000.
- Biquetoast
- King Jeremy The Wicked
21 Aug 2007 19:30
bubba_d wrote:
Did you check *inside* the side cover where the other end of the cable is? There's a little spring that's supposed to hold it seated even when slacked, but it may have popped out.now able to fully release however it grabs almost all the way out. checked entire cable. no kinks.
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- bubba_d
