Tolerences for Valve Shimming
- Unitrak
20 Aug 2007 18:23
Hi all:
I've checked valve clearances and found that some will need new shims and some are near tolerance. So, should re-shim only the ones that are out of spec? or re-shim more valves so that everyone is within spec?
Or, should I go as far as re-shimming so that all are as close to middle of tolerance as shim sizes will permit. :blink:
83GPz750, yosi 4/1, factory airbox, jetted, 94k, topend rebuilt at 71k
Many thanks in advance
- Samwell
Re: Tolerences for Valve Shimming
21 Aug 2007 05:30
Unitrak wrote:
AKAIK, the current recommendations from the air cooled guru's is to shim all the valves to the looser end of the spec. Yes this means the valves may tick a little more, but as the they wear, they have a tendency to tighten up and a valve thats quietly too tight may go un-noticed and cause trouble i.e.: it can burn.
hope this helps...Sam
Hi all:
- A2-Cow-A-Socki
21 Aug 2007 08:33
I just did mine yesterday, and I think I did them sloppy. (Im a bit out of the KZ Loop) I wouldnt though if you are using under a 230 shim. I am running 265's almost all across with 6 clearance and ill recheck them in the spring. Its no big deal to change if you have the spacer tool.
- Unitrak
23 Aug 2007 07:10
Thanks for the info, I'll aim to be on the loose side as I've allways been a bit of a slacker;)
