Cam chain tensioner
- ricerocket
Cam chain tensioner
18 Aug 2007 11:36
My question is when should i adjust my camchain?And how?
What if any sounds would there be?How often should my valves be checked?
Any help would be appreciated.
- The Milkman
Re: Cam chain tensioner
18 Aug 2007 11:42
It helps alot if you put you bike year and model in your sig line so we know which bike you are talking about. If you have an automatic adjuster you don't have to worry about it but if it's manual then you do. I used to check mine twice during the riding season but now that I switched to and automatic I don't worry about it. I just take it off and clean it during the winter down season.
Ride safe.
Ride safe.
- ricerocket
- mark1122
- Keep twisting it
19 Aug 2007 00:53
for a 76kz u put #1 at tdc and loosen the tentioner lock nut and bolt.then the spring inside will take up the slack.then u retighten the bolt and lock nut.done.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
