Top Speed
- ricerocket
Top Speed
17 Aug 2007 22:23
I was reading a post earlier on top speeds.And one guy asked how fast will these kzs go.One guy replied real top speed is prob 115 mph.
I have a 1978 Kz1000 1075 kit,29mm flatslides,Header,!5 tooth front sprocket,33 rear.
I had my speedo checked it is 3mph fast.
Tonight i was in third gear 100mph at 8500 rpm.It was dark so i backed off there lot of deer around here.
So for me i will keep ya posted but i think i can pass 135 easy.And it did not take long to get there.
- oldkaws4ever
- Have no regrets...... You only live once.
Re: Top Speed
18 Aug 2007 00:30
i have a stock 1974 z1 900, and i have had it up past 100 mph many times with no probs. Tonight i was out on the highway, i kicked it up to around 105, man was that kinda freaky, needless to say i only held it there for a couple of seconds.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- larrycavan
Re: Top Speed
18 Aug 2007 03:43
Guys...watch out for those deer....Seriously...they come out of nowhere and they get no traction on paved roads....
Keep yourself Alive
Keep yourself Alive
- BohicaBob
- flht1997
Re: Top Speed
18 Aug 2007 06:57
ok i am not sure of your ratios and what you go to for redline. but going off the specs page
if we say 8500 redline. a 2.190 primary ratio, 1.040 fifth gear ratio. and your final of 2.2 added up to a final overall ration of 5.430. which when divided gives you 1565 rpm of the rear tire. estimating about a 80 inch circumference gives you a forward travel of 125230 inches per minute. then cross multiply with i mile per minute gives you a speed of about 118 mph.
now if you spin it up to ten grand you would be going about 139.5 mph
now i figured in a few estimates and guesses but numbers do not lie.
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
- Ray J
Re: Top Speed
18 Aug 2007 08:31
Or, Matt, you could just gun it!!!
124 mph here. But... is the speedometer right? I think they used to bump up the speedometer reading so you think you are going faster.
Post edited by: Ray J, at: 2007/08/18 11:33
- ricerocket
- RetroRiceRocketRider
Re: Top Speed
18 Aug 2007 11:33
Ray J wrote:
All of the speedos on older bikes like ours are slightly "optimistic".
ex: indicated speed - 124 mph
actual speed - 119 mph
Mount a lower or higher profile tire (or smaller/larger diameter wheel) on the front, and it can throw the indicated and actual speeds off even more.
124 mph here. But... is the speedometer right? I think they used to bump up the speedometer reading so you think you are going faster.<br><br>Post edited by: Ray J, at: 2007/08/18 11:33
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- PLUMMEN
Re: Top Speed
18 Aug 2007 13:54
id say its safe to say the top speed no matter what it may be greatly exceeds what the average person will ever attempt and what any of the roads around these 50 plus states are capable of handling safelyB)
- Virii
- I like cheese
Re: Top Speed
18 Aug 2007 15:08
I just tweaked 40mph out of my girl's Ciao...
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- Z1R rider
Re: Top Speed
18 Aug 2007 18:42
Ratios for a 900 or 1000 are
primary- 1.73
5th gear- 1.22
rear (w/15-33)- 2.20
if you can pull 8500 in high you'll be around 147 mph with a 26" rear tire, better be down hill & with the wind if stock. :laugh:
about
57 in 1st
82 in 2nd
107 in 3rd
130 in 4th
primary- 1.73
5th gear- 1.22
about
57 in 1st
82 in 2nd
107 in 3rd
130 in 4th
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
