rotor madness
  • themachine
  • themachine's Avatar Topic Author
rotor madness
14 Aug 2007 19:40
#163959
theres this weird humming/rubbing sound coming from my stator cover whenb i accellerate and decellerate, i can also feel a vibration when i have my hand on it when it happens.
i'v heard of the rotor spinning on the crankshaft on J motors when raced hard, but if this happend how the hell do i fix it!?:S
i'm not going to pull the cover untill i get a gasket.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • A2-Cow-A-Socki
  • A2-Cow-A-Socki's Avatar
Re: rotor madness
21 Aug 2007 10:30
#165407
You spun the bolt loose that hold the rotor on, if you let it spin it will cut grooves into the crank and you wont be able to use the electric starter.
What you are hearing is your rotor cutting into your stator. It happened to me too.
  • themachine
Re: rotor madness
22 Aug 2007 03:15
#165560
i found the problem, the stator was loose on the cover.
my starter clutch lets go occasionally when its warm.
