BURNING A $H!TLOAD OF OIL!!!
  • furby1184
  • furby1184's Avatar Topic Author
14 Aug 2007 13:35
#163860
my 79 kz650b is burning a whole lot of oil, any ideas as to why?
1979 KZ 650B pod filters, 4-1 kerker.
  • mariozappa
  • mariozappa's Avatar
Re: BURNING A $H!TLOAD OF OIL!!!
14 Aug 2007 13:37
#163861
Your piston rings might have given way.
Have you done a compression test?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
14 Aug 2007 13:40
#163865
check crank case breather
  • tjettim
  • tjettim's Avatar
14 Aug 2007 13:49
#163869
Re:BURNING A $H!TLOAD OF OIL!!!
It is simple,your motor is now
a piece of crap.:laugh:
Could be a broke piston ring if it
started all at once.That is what
happened to mine this spring.
  • BSKZ650
  • BSKZ650's Avatar
14 Aug 2007 14:06
#163876
if its burning that much oil it has got to be way down on power, as stated run a compression check, then check the valve adj, you need some type of baseline in which to start with
77 ltd1000, current rider
76 kz900, just waiting
  • reborn650
  • reborn650's Avatar
14 Aug 2007 14:10
#163879
It might help to pinpoint the problem if you indicated if the oil was coming out of the crankcase breather or through the exhaust.
If it is coming out of the exhuast, as mariozappa mentioned, do a compression check first. If your compression is up in the 140 + psi range you should be good. The spark plugs might give you an indication if there is one particular cylinder that is causing problem. If you have a real sooty/black plugh I would suspect valve seals might be a possible cause of the oil burn.
-1998 Jeep TJ Wrangler 4.0...
14 Aug 2007 18:32
#163932
Has crankcase oil been checked for possible contamination by fuel intrusion into crankcase? :)
  • RonKZ650
  • RonKZ650's Avatar
14 Aug 2007 18:52
#163940
How many miles on the engine and what exactly constitutes a $hitload? After 160,000 miles I was burning a quart every 200 miles. Is that considered a $hitload? I was basically changing my oil as I rode because it was about 13 quarts of oil used during every 2000 mile change interval. Bike still didn't smoke and ran good believe it or not. Oil was so sludged up it wouldn't drain last time I attempted an oil change. It was all a joke to me to see how far the bike would go.
  • themachine
  • themachine's Avatar
14 Aug 2007 19:33
#163955
do you still have this 160,000,mile wonder?
if not what happend?
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
  • RonKZ650
  • RonKZ650's Avatar
14 Aug 2007 21:34
#163989
I have the motorcycle, the engine is retired deservedly. Got a 15,000 mile KZ650 engine in there now.
