- Thank you received: 43
Cam Degreeing - another question
- 79MKII
- Love Them Kaws!
Why does valve lash have to be set to Zero?? Can an adjustment be made to compensate for valve lash? I really don't want to pull the cams over and over again so I'd rather degree them with the lash already set (.004-.006). Can anyone offer opinions on degreeing with some vlave lash present? (KZ1000, shim under bucket set up)
Thanks
The Kaw List:
- PLUMMEN
- Thank you received: 104
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- modprod
In using the "lobe center method", valve lash is not a factor on these motors. Lash or checking height has no effect on lobe centerline. Lash effects "duration" but has no relationship to centerline. So degree away and don't worry about your lash.OK, I have read articles, watched videos, and gone over nearly every thread on KZR covering cam degreeing. I think I can get them set using the lobe center method, but I'm still having trouble understanding something.
Thanks
- 79MKII
- Love Them Kaws!
I have read several articles that back up what you're saying, but why is it that most places still recommend removing all lash? Even web cams, where I bought my new cams, says to remove all lash. I just don't understand why??
The Kaw List:
- jimmybon
I made it easy buy setting up my daughters video camcorder linked to a portable TV fixed on the degree wheel on the alternater side. So I can do all the turning of the crank from the points side and recording the dial indicater measuring from one side of the bike
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
- larrycavan
- Visitor
I can understand wanting to not have to pull the cams out again but it's lot easier to get them dead on by assembling just two valves in the head with light springs. Fighting the heavy valve spring to get a half a degree can be a pain in the arse...
Main thing is to be certain you have accurately found TDC using a positive stop.
Post edited by: larrycavan, at: 2007/08/13 05:23
- 79MKII
- Love Them Kaws!
It's fine to degree them at running lash...
...Main thing is to be certain you have accurately found TDC using a positive stop.<br><br>Post edited by: larrycavan, at: 2007/08/13 05:23
OK, I'm finally ready to actually degree these cams and the positive stop contacts the intake valve. I'm using the Dale Walker kit and he casually mentions in the video that the positive stop "may have to be turned down". I don't happen to have a lathe handy!!
Is there an easy solution to this major problem? I'm stopped dead in my tracks right now...
The Kaw List:
- modprod
Pull the cams. I always find TDC with a positive stop before installing the cams, no interference problem that way
- 79MKII
- Love Them Kaws!
Well, that's not quite the "easy" solution I was hoping for but it sure makes sense. I guess it's time to remove the cams for the 4th time. At least I'm getting real good at it! Practice makes perfect you know!
Seriously though, that should work just fine. I can't think of any problems it would cause and it is certainly the safest way. No valve damage, guaranteed. Thanks for the tip.
The Kaw List:
- 79MKII
- Love Them Kaws!
Web suggests .006". It can be pretty hard to be perfect, so is it better to be a little loose (.007) or a little tight (.005)? I'm guessing a little loose because things should tighten up as the new parts wear, correct?
The Kaw List:
- mark1122
- Keep twisting it
- Thank you received: 109
u can make your own tdc stop buy gutting a spark plug then putting 3" x1/4".bolt through the center with a nut on each end to hold it in place.just adjust the nuts so the bolt sticks out about a 1/2" total and tweek as needed. once its set u never have to change it.
its easy cheap and works perfect.
i use a vice grip chain around the stator to turn over the motor with no plugs.
i just subtract the lash from the lift .so if i want .050" lift and have .004 lash .i set lift at .044".and it works great.this way your # will be very close to Web's cam specs.
Now just lossen 2 cam bolts and leave 1 that u can access snug.now when u set the lift to where u want and the degree wheel says u have to advance the cam say 2 degrees,just loosen that last bolt, advance the crank 2 degrees and the cam will not move.now retighten the cam bolt and recheck.continue untill u get it where u want it.
works for me ,hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
