wierd hole in my engine!
- wolfpakk
10 Aug 2007 13:08
Hi! I'm in progress of bringing a old kz1000 mk2 to life again. Bought it with engine in a case and know nothing of its history. I have got it running but its far from complete. Now i need a few inputs about my crankcase... it has a hole as you can see on the pics. Need advise on what i should do about it.
- wolfpakk
- cnyl
Re: wierd hole in my engine!
10 Aug 2007 13:52
I love those bikes. Wow that hole can't be good.:huh:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- BARNEYHYPHEN
10 Aug 2007 14:21
Think I'd JB Weld a small, slightly bigger than the hole all around, piece of 18/16ga aluminium over it.
- Jeff.Saunders
10 Aug 2007 15:26
It's on all Z1 KZ900 / KZ1000 (77-80) engines...
...it's just a drain hole for any water sitting on the top of the cases.
www.z1enterprises.com
Z1 Ent on Facebook,
- mark1122
- Keep twisting it
10 Aug 2007 17:17
Jeff is right .dont wory be happy:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Nephlyte
- To do what is right is to know what you want.
11 Aug 2007 15:55
Jeff.Saunders wrote:
Damn, you beat me.
Damn, you beat me.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
- donthekawguy
11 Aug 2007 16:08
Sorry the bike is toast. Go ahead and send it to me. I'll even pay shipping to take it off your hands. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- wolfpakk
12 Aug 2007 01:24
That sounds great, i was about 100% sure it should not be like that. Thanks!
- wolfpakk
12 Aug 2007 10:48
donthekawguy wrote:
I almost had it for free, they are not worth so much in Sweden. But its a nice bike and its pretty easy and cheap to repair. Think I keep it and maybe get a 1075 kit and other cams.
- wolfpakk
12 Aug 2007 10:57Post edited by: wolfpakk, at: 2007/08/12 13:59
- turbodog
18 Aug 2007 16:59
One of my fist bikes was 81 Yamaha Sega 550 with a 4 into 1 kerker. It had a about one cm diameter hole on the right side of the case towards the bottom. I tried JB Welding it about three or four different times but that hot oil would usually start leaking after a few weeks, making a mess of the bike and me, and smoking up. Finally, on about the fifth try I did something right and the JB Weld worked! That bike never leaked oil again. So I say, clean the area around the hole on your KZ real good and apply a good mix of JB Weld and the hardener and it should work.
