wierd hole in my engine!
10 Aug 2007 13:08 #163070 by wolfpakk
wierd hole in my engine! was created by wolfpakk
Hi! I'm in progress of bringing a old kz1000 mk2 to life again. Bought it with engine in a case and know nothing of its history. I have got it running but its far from complete. Now i need a few inputs about my crankcase... it has a hole as you can see on the pics. Need advise on what i should do about it.
10 Aug 2007 13:09 #163072 by wolfpakk
Replied by wolfpakk on topic wierd hole in my engine!
closer pic!
10 Aug 2007 13:52 #163088 by cnyl
Replied by cnyl on topic wierd hole in my engine!
I love those bikes. Wow that hole can't be good.:huh:
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
10 Aug 2007 14:21 #163097 by BARNEYHYPHEN
Replied by BARNEYHYPHEN on topic wierd hole in my engine!
Think I'd JB Weld a small, slightly bigger than the hole all around, piece of 18/16ga aluminium over it.
10 Aug 2007 15:26 #163107 by Jeff.Saunders
Replied by Jeff.Saunders on topic wierd hole in my engine!
It's on all Z1 KZ900 / KZ1000 (77-80) engines...
...it's just a drain hole for any water sitting on the top of the cases.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • mark1122
  • Keep twisting it
10 Aug 2007 17:17 #163117 by mark1122
Replied by mark1122 on topic wierd hole in my engine!
Jeff is right .dont wory be happy:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Nephlyte
  • To do what is right is to know what you want.
11 Aug 2007 15:55 #163242 by Nephlyte
Replied by Nephlyte on topic wierd hole in my engine!
Damn, you beat me.
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
11 Aug 2007 16:08 #163245 by donthekawguy
Replied by donthekawguy on topic wierd hole in my engine!
Sorry the bike is toast. Go ahead and send it to me. I'll even pay shipping to take it off your hands. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
12 Aug 2007 01:24 #163324 by wolfpakk
That sounds great, i was about 100% sure it should not be like that. Thanks!
12 Aug 2007 10:48 #163396 by wolfpakk
I almost had it for free, they are not worth so much in Sweden. But its a nice bike and its pretty easy and cheap to repair. Think I keep it and maybe get a 1075 kit and other cams. B)
12 Aug 2007 10:57 #163402 by wolfpakk
Post edited by: wolfpakk, at: 2007/08/12 13:59
18 Aug 2007 16:59 #164702 by turbodog
Replied by turbodog on topic wierd hole in my engine!
One of my fist bikes was 81 Yamaha Sega 550 with a 4 into 1 kerker. It had a about one cm diameter hole on the right side of the case towards the bottom. I tried JB Welding it about three or four different times but that hot oil would usually start leaking after a few weeks, making a mess of the bike and me, and smoking up. Finally, on about the fifth try I did something right and the JB Weld worked! That bike never leaked oil again. So I say, clean the area around the hole on your KZ real good and apply a good mix of JB Weld and the hardener and it should work.;)
