very hot engine ....
  • scaf
  • scaf's Avatar Topic Author
08 Aug 2007 22:14
#162684
salute !
I have next problem : after a few Km my engine become very very hot untile he stoped indifferent with what speed i'm going ..i'm not shure the carburattions is ok ...how cand I verify adjustment at carburettors ?
tnx
  • Makarth
  • Makarth's Avatar
Re: very hot engine ....
08 Aug 2007 22:27
#162687
use the secondary jets (use the choke) and see if it fixes or helps
and check your oil because that can be a huge issue with oil cooled bikes.
1977 kz1000 - Megasquirt project @ 40% wiring, plenum, and exhaust<--(done!)
09 Aug 2007 03:52
#162711
Also check --
Ignition timing
Timing advancer unit
09 Aug 2007 04:44
#162717
And also check for correct ---
Spark plugs
Spark plug heat range
Spark plug gap
Missing or damaged air filter
Leaking carb intake hoses (between carb and airbox)
Oil level -- too high or too low
Oil viscosity -- too low (thin) or too high (thick)
Brakes dragging
Carb holders (between carb and engine)-- damaged, cracked, or loose. Clamps tight? Vacuum plugs sealing okay?
Service float bowl fuel level (perform clear plastic tube test)
Air pressure in tires
Obstructed engine cooling fins
Clogged muffler
Wheels turning free (bearings okay)
Good Luck! :)
Post edited by: Patton, at: 2007/08/09 07:50
  • scaf
11 Aug 2007 12:33
#163217
salut again ! ...
I check all this staff but ...: I speak with my frends and they say it is from carburettors
can you tell me how carburettor must be adjustment ? they say is too few gas ..or too much air ..
it is necessarily an special tools for this ?
TNX
  • kzwolfsr
  • kzwolfsr's Avatar
12 Aug 2007 19:28
#163456
It can be from the carbs if the fuel mixture is too lean. clean your carbs or adjust fuel air mix screws. I don't know what bike you have so I can't tell you where those are!
Original man of the Caribbean
  • JMKZHI
  • JMKZHI's Avatar
Re: .
13 Aug 2007 05:52 - 03 Dec 2008 09:56
#163501
del
Last edit: 03 Dec 2008 09:56 by JMKZHI.
