Oil covered engine
- edjo69
Oil covered engine
07 Aug 2007 18:56
Hello, I am working on a 79 kz650c for my friend. I am re-doing the carbs for him. Heres the next issue, the entire front of the engine is covered in oil, from the valve cover down to the bottm, being thicker at the lower portion. Bike has been sitting for quite awhile so it may have been accumulating over time. I searched a bit a found an overwhelming number of oil leak threads. So my question is this, what is the likly culprit?? Thank you very much, Ed
- PLUMMEN
Re: Oil covered engine
07 Aug 2007 19:00
i would guess the valve cover gasket to be a good starting point,but id take it to the carwash and give it the scrub and rub first to make the process easier.
- RonKZ650
07 Aug 2007 19:48
Valve cover can leak, but that's a man-made leak from taking the cover off and putting it back on with a bad gasket or crap on the surface. A valve cover gasket will never just start leaking out of the blue sky on it's own if it was sealing at one time. Same with the head gasket and base gasket. These can still leak, but KZ650 is covered in rubber orings that will leak. On the front of the engine you have the tachometer drive with 2 rubbers there, also the 4 cam end plugs and the orings between the head and cylinder and the cases and the cylinder. Only the tach drive is on the front of the engine though. Like plummen said though, oil leaks can be elusive as oil runs all over the place after it leaks so clean her up and see whats going on.
- wiredgeorge
08 Aug 2007 05:52
You can go through and fix every possible leak point or you can clean the engine thoroughly and then buy a can of powder-based spray deodorant. Spray a little bit on everything then start the engine. The oil leak will soon show in the fine covering of powder. Fix that spot.
- edjo69
08 Aug 2007 10:45
All good info, thank you. I will start with a good engine degreasing at the car wash and start checking mentioned spots. Thanks alot, Ed
- BSKZ650
08 Aug 2007 11:18
make sure you cover the carbs, if you dont have a stock air box on it
77 ltd1000, current rider
76 kz900, just waiting
- KaZooCruiser
08 Aug 2007 11:24
edjo69 wrote:
Tach seal:
elegant fix for same
Tach seal:
- edjo69
08 Aug 2007 17:49
Ok, Bike is back from the car wash all clean and fancy. Tach drive is way loose, should I go ahead and replace the seal and o-ring? Can I get the parts from Bikebandit? Thanks again guys for all of your help, Ed
- austin3119
08 Aug 2007 17:51
Bike Bandit is all right. For more personal service take your business to Jeff at z1enterprises.com .
Good luck.
Good luck.
