How Hot?
- Powder Keg
I don't know how to get it to cool down? I set the valve clearance. Could the oil pump be going out on this? I don't have a oil cooler yet but I'm going to add one soon. Any suggestions would be appreciated.
Thanks, Wes
- Powder Keg
Can I add a oil pressure gauge anywhere on here and how much pressure should it have? Thanks, Wes
- Sandy
- Fly High,Tony
- Thank you received: 13
I have them installed on My snowmobile,and they're used for jetting purposes.You jet where You think You want to be,and the pyro will give You an exhaust temp reading,and from there You jet leaner or richer depending on the reading You get.
Aluminum melts down at 1100 degrees F,so You would use the pyrometer to get You close to that,to get the leanest,most effective jetting(for a snowmobile).
1977 KZ1000 A-1
- Powder Keg
- tjettim
- Thank you received: 2
You might want to richen the carbs up a bit.
What speeds does the bike seem to run hot at?
- steell
I have an optical pyrometer good to 500 degrees. I got it at radio shack. You just point it at the object and it will tell you the temp;)
I'm like Sandy, I believed that Pyrometer referred to exhaust gas measurement as well, but I looked it up on wikipedia and you are quite correct in calling what I refer to as an infrared thermometer a pyrometer.
en.wikipedia.org/wiki/Pyrometer
I have no idea what would be an acceptable temp at any specific external location though.
- Powder Keg
- Virii
- I like cheese
I love those, use one in my kitchen (ala Alton Brown) but while 500 degrees is fine for a pan of hot oil....do you think it'll be enough for your engine? I'm not sure...
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- trippivot
- Thank you received: 3
if you are concerned about melting aluminium there will be little bits of grey balled material on the plug electrode.
get a optical or look into the spark plug hole with the piston at T.D.C you will definately see the detonation scars if there are any
ignition timing is the tuning detail that will raise the temp most
don't forget these bikes will get oil temps of near 300 F. in the summer
I like to run ngk b9es in the summer it is 2 steps colder that what is recomended
- Virii
- I like cheese
- Powder Keg
