argh! found first weak link
  • 810gpz750
  • 810gpz750's Avatar Topic Author
04 Aug 2007 19:24
#161765
replaced exhaust and rebuilt/rejetted carbs and added pingel petcock. all great till head gasket gave out and my cam plug on rear cam left side and valve cover gasket! damn! any suggestions on where to get a good head gasket oem is $85 would like to find a cheaper replacment as i plan to go to the 810 kit soon. also would like to know where to get the aluminum cam plugs. thanks in advice for any suggestions.
  • The Milkman
  • The Milkman's Avatar
Re: argh! found first weak link
04 Aug 2007 20:38
#161782
A good start would be Z1enterprises.com.
Ride safe
  • Mark Wing
  • Mark Wing's Avatar
04 Aug 2007 22:29
#161791
Not sure if anyone makes them for the 650's. The ones I have are for a 900/1000 that I filed down to fit.
Mark
Yorba Linda Cal.
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
05 Aug 2007 09:33
#161851
The Cometic graphite gasket is supposed to be good for the GPz750. APE do the metal half moons but the rubber ones are just as good (if not better).
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • 810gpz750
05 Aug 2007 11:52
#161880
thamks for the advice. ive only had the bike for a little over a month. i got a good deal on it i think just trying to get everything right before i make it better. this week i will fix the gaskets and probably check and clean my valves while im at it. i also plan on putting in a new clutch because my slips in the high rpm range. will try to post pics in a little while.
  • 810gpz750
05 Aug 2007 11:53
#161881
  • 810gpz750
05 Aug 2007 11:53
#161882
  • Frank
  • Frank's Avatar
05 Aug 2007 11:56
#161884
I bought i full athena gasket set from the motovan catalogue for $116 canadian. This includes everything you need except cam plugs. It even comes with new exhaust gaskets and valve seals.
  • 810gpz750
05 Aug 2007 17:55
#161940
looks like i am going with cometic for the head gasket and z1 for cam seals and plugs for about $60 not bad for the needed gaskets. appreciate the help guys.
