- Thank you received: 8
1075 head gasket question
- donthekawguy
04 Aug 2007 15:06 #161737
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1075 head gasket question was created by donthekawguy
I just got my bike running yesterday and it runs really bad. It is firing on all four but when you twist the throttle it wants to die. I didn't think of this before but saw a post about copper head gaskets. I used a stock size head gasket with the 1075 kit. Are there head gaskets for the 1075 or will the stock size work?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Sandy
- Fly High,Tony
- Thank you received: 13
06 Aug 2007 00:44 #161990
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic 1075 head gasket question
Did You use a 1-piece,or a 2-piece head gasket,and did You use the spaghetti-ring(0-ring seal)in the center of the head?
If You DID use a 1-piece had gasket,and You installed that 0-ring,chances are You're head gasket is leaking.
Went through that with Mine a couple years ago,Don.
So if You DID...be prepared to pull the head again Bud.
1977 KZ1000 A-1
- donthekawguy
06 Aug 2007 01:13 #161991
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Replied by donthekawguy on topic 1075 head gasket question
Nope used a two piece set. Bummer. Oh well it's all torn down now. Now I have to do it right. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- racer54
- Thank you received: 114
06 Aug 2007 11:59 #162059
by racer54
Replied by racer54 on topic 1075 head gasket question
I used the inner o-ring and two-piece gasket on mine...no problems. Copper head gaskets are made for high compression and you need to have cylinders o-ringed to seal the copper.
- Nephlyte
- To do what is right is to know what you want.
06 Aug 2007 13:16 #162075
by Nephlyte
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
Replied by Nephlyte on topic 1075 head gasket question
The only thing i know is that wiseco and cometic list different gaskets for 1015 engines and 1075 engines.
So i go with the one listed for my engine size.
