Cam timing question...74 Z1
- bLodi
04 Aug 2007 14:10
I just pulled my cam cover off and was inspecting my cam timing and was wondering...Should the cam marks be horizontal when the crank is on the "T" mark or on the "F" mark?
Right now they are on the "F" mark and I think that might be wrong and they need to be "retarded" one tooth so they line up at the "T" mark.
Thanks for any help.
www.blodisign.com
\\\\\\\'74 Z1
V&H 4-1 Header, Pod Filters, Dyna Ignition, Dyna Coils, Dyna Wires, lowering kit...much more.
\\\\\\\'74 Z1
- donthekawguy
Re: Cam timing question...74 Z1
04 Aug 2007 15:03
I just did mine yesterday and set them on the T mark. I have heard that you can set them one tooth off but not sure which way.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- bLodi
04 Aug 2007 15:06
It must be you can run it one tooth advanced. I just did new rings on mine about 100 miles ago and havn't had any problems. Just noticed I was missing some power up top...I think this is why.
www.blodisign.com
\\\\\\\'74 Z1
\\\\\\\'74 Z1
- coppertales
05 Aug 2007 10:53
If you don't hae a manual for your bike, BUY ONE. It has a nice diagram showing the proper way to time your cams.......I guessed once and bent some valves........chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
