1075 copper gasket?
- Nephlyte
- To do what is right is to know what you want.
Now, Cometic has a two piece copper gasket for that size bore(which is 72mm). Has anyone used a copper gasket with a 1075 kit in their KZ? Does it work good, leak oil?
Also, how reusable are they?
1979 KZ1000 MKII, 1075 wiseco kit installed, 10.25:1 compression, welded crank, kerker header and custom paint.
- PLUMMEN
- Thank you received: 104
- wallyworld
- wallyworld
- wallyworld
- Bad Kaw
- Flying Squirell
- Thank you received: 13
copper gaskets normally leak like a sieve unless the top of sleeves is o ringed;)
Yep. Had the exact same experience with my 1260.
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
- Thank you received: 2098
The 1 piece head gasket first used on Z1 was changed to a 2 piece version on late 73's and became standard on 74 models with taller cylinder head nuts.
I believe the rubber o-ring between the two halves sealing off the cam chain tunnel was also introduced with the 2 piece head gasket.
- tjettim
can,fibre if you can't.If you run the copper
it will just be a matter of time untill it
leaks.Have your head checked for flatness,
have it skimmed in a mill if it shows ANY
warpage or dips across it.
- Nephlyte
Get another Cometic gasket.Graphite if you
done and done. Thanks for the help guys.
- APE Jay
- Banned
- Thank you received: 58
Cometic only shows 71 and 74mm 2 piece copper in the 07 catalog. Maybe they have 72 on their website.
We generally recommend copper only when cylinder pressure is too high for the fiber gaskets.
Jay
Post edited by: APE Jay, at: 2007/08/06 21:10
- trippivot
- Thank you received: 3
they do leak if you don't use gasket cinch be sure to let the glue dry before installation
good O rings are necessary as well
I love copper and use them a lot over and over
even if they do leak a bit
