Twin Valve Stem Seals
  • gs1100g
  • gs1100g's Avatar Topic Author
02 Aug 2007 01:18
#161277
Can anyone help with sourcing Valve Stem Seals for an 82 750 twin? Genuine aren't available any more and even Z1 can'thelp.
Tks Ppl , Trevor, Australia.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Twin Valve Stem Seals
02 Aug 2007 04:50
#161285
Trevor, Drop Steell (Steve Elliot) a note. He will know the answer to this one. I suspect aftermarket seal for a 900/1000 will work fine but since I have never worked on a 750 twin, I can't say for sure. I use the same seals on Vulcans as the 900/1000 so they are kind of generic in nature.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
02 Aug 2007 05:23
#161291
For what it's worth, it's part number 92049-017, VALVE OIL SEAL, and was used on KZ750 twins from 76 - 83 (and the mysterious 84 Canada-only model).
I cannot say if they were similar to others or not, I only got this from the Kawasaki cross-reference software.
Have you looked into those oil seal/gasket kits you find on eBay every once in a while? They should probably be in there, and maybe that might cost you more than you want, but if they are otherwise extinct, it might be your only way to go....
Post edited by: Biquetoast, at: 2007/08/02 08:28
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Aug 2007 06:36
#161300
I second Biquetoast...check on eBay...they are usually included in a full gasket set. On eBay, there is a full gasket set currently for sale (eBay 200129615083) but it is, unfortunately for a 1976 B1...I don't know how this translates for your 750(2), but the valve stem seals are the same.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
