kz650b2A revs and redlines
01 Aug 2007 14:28 #161193 by franco
kz650b2A revs and redlines was created by franco
Hi all,
My kz650b2a seems to be a bit obscure, I have found very little data on this bike, lots on B2 and B1 but not on B2A and after my experiences with the parts diagram, I know there are differences. here is the issue:
The Tach and Speedo are toast on this bike, I ride with a GPS and it keeps the speeding tickets away, but It seems to me that I am revving very high to sustain 90-100kms (60 mph) in my top gear. Other people have told me that there is a problem, that this bike should do at least a comfortable 100km/h does anyone know what the RPM redline equivalent would be in kmh/mph for each gear? If I had a clue about the RPMs while riding I would probably be more comfortable and not worry so much about over revving to run highway speeds. note for all purposes this bike is stock except the airbox is gone and K&N style filters are attached to carbs.....
Thanks for any and all!
Franco
Post edited by: franco, at: 2007/08/01 17:30
01 Aug 2007 18:31 #161219 by 650ed
Replied by 650ed on topic kz650b2A revs and redlines
Franco,
KZ650's run at fairly high rpm, but without a tach you won't be able to do much more than guess. I took a look at Kawasaki.com and it shows part #25015-1011 as the tach for several KZ650 models including the B2A:
• KZ650-B1 (1977)-->METERS/IGNITION SWITCH
• KZ650-B2 (1978)-->METERS/IGNITION SWITCH
• KZ650-B2A (1978)-->METERS/IGNITION SWITCH
• KZ650-B3 (1979)-->METERS/IGNITION SWITCH
• KZ650-C1 Custom (1977)-->METERS/IGNITION SWITCH
• KZ650-C2 Custom (1978)-->METERS/IGNITION SWITCH
• KZ650-C3 Custom (1979)-->METERS/IGNITION SWITCH
• KZ650-F1 (1980)-->METERS
These tachs (and the matching speedometers) are often on eBay, in fact there are a couple nice ones on there now. I can't say how much$ they go for or if they're in your budget, but take a look at Kawasaki.com to see if the speedometer is shared by the B2A with the other models shown for the tach. You may be able to get them both for a good price. Good luck. Ed
01 Aug 2007 19:36 #161233 by rstnick
Replied by rstnick on topic kz650b2A revs and redlines
On my 650C2 the engine is reving at about 5000~6000 rpm in 5th at 100 KPH. This is not very high, as the redline is up around 9000 rpm.
I switched to Kawasaki Synthetic Oil recently. I'm finding it has affected my rpms in a good way. The engine revs a lot freer and smoother. I used to cruise around 80 KPH in 4th gear most of the time before, but am finding now with the synthetic oil, I will often find myself in 3rd gear at 80 KPH.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
02 Aug 2007 00:22 #161272 by Dave Sloan
Replied by Dave Sloan on topic kz650b2A revs and redlines
When my 650 was new and had standard gearing it would run at 5600rpm at 120kph and somewhere around 200kph at 9000
Z650B2 - Injected
02 Aug 2007 05:26 #161293 by BSKZ650
Replied by BSKZ650 on topic kz650b2A revs and redlines
check the gearing on the bike, someone may have changed it prior to you getting the bike
77 ltd1000, current rider
76 kz900, just waiting
02 Aug 2007 06:36 #161301 by Bluemeanie
Replied by Bluemeanie on topic kz650b2A revs and redlines
Mine with stock gearing (16/42) runs 60mph @ 5000rpm, 70mph @ 6000rpm.
02 Aug 2007 08:56 #161329 by fixer5000
Replied by fixer5000 on topic kz650b2A revs and redlines
i wanna know what the difference is from a b2- b2a?? anyone know??
1978 kz650b pretty much stock
massachusetts
02 Aug 2007 12:18 #161375 by Patton
Replied by Patton on topic kz650b2A revs and redlines
Gonna guess the "a" signifies model approved for sale in California (stricter emissions laws). :)
03 Aug 2007 07:11 #161522 by cafekz750
Replied by cafekz750 on topic kz650b2A revs and redlines
I think you may want to think about re-jetting the carbs if you are running individual pod filters on the carbs. That is too much air for the stock jetting. This will effect how the bikes feels while riding at highway speeds.
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
03 Aug 2007 10:31 #161550 by rstnick
Update, after a ride last night.
My bike actually revs at 4800 rpm at 100 KPH, in 5th gear. Normally I would not ride in 5th at this low an rpm, I'd be in 4th at 100 KPH, unless it's really flat land or I'm going down hill.
I've found the Kawi Sythetic Oil has changed my riding rpms. Much more power and freer reving than with the old recycled cheep oil I was using before.:)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
04 Aug 2007 05:59 #161680 by Bluemeanie
OK Rob, nothing makes sense until I know what the heck 100kph is? Us Americans need that foolish "mph" stuff! Is there a basic formula for converting this? :blink:
04 Aug 2007 06:09 #161682 by Bluemeanie
OK never mind, I went outside and looked at the "little blue" numbers on my spedo. Do you guys have "little american numbers" on your spedos? So at 100kph I'm doing about 5300rpm's in 5th.
