kz650b2A revs and redlines
- franco
My kz650b2a seems to be a bit obscure, I have found very little data on this bike, lots on B2 and B1 but not on B2A and after my experiences with the parts diagram, I know there are differences. here is the issue:
The Tach and Speedo are toast on this bike, I ride with a GPS and it keeps the speeding tickets away, but It seems to me that I am revving very high to sustain 90-100kms (60 mph) in my top gear. Other people have told me that there is a problem, that this bike should do at least a comfortable 100km/h does anyone know what the RPM redline equivalent would be in kmh/mph for each gear? If I had a clue about the RPMs while riding I would probably be more comfortable and not worry so much about over revving to run highway speeds. note for all purposes this bike is stock except the airbox is gone and K&N style filters are attached to carbs.....
Thanks for any and all!
Franco
Post edited by: franco, at: 2007/08/01 17:30
- Thank you received: 2829
KZ650's run at fairly high rpm, but without a tach you won't be able to do much more than guess. I took a look at Kawasaki.com and it shows part #25015-1011 as the tach for several KZ650 models including the B2A:
• KZ650-B1 (1977)-->METERS/IGNITION SWITCH
• KZ650-B2 (1978)-->METERS/IGNITION SWITCH
• KZ650-B2A (1978)-->METERS/IGNITION SWITCH
• KZ650-B3 (1979)-->METERS/IGNITION SWITCH
• KZ650-C1 Custom (1977)-->METERS/IGNITION SWITCH
• KZ650-C2 Custom (1978)-->METERS/IGNITION SWITCH
• KZ650-C3 Custom (1979)-->METERS/IGNITION SWITCH
• KZ650-F1 (1980)-->METERS
These tachs (and the matching speedometers) are often on eBay, in fact there are a couple nice ones on there now. I can't say how much$ they go for or if they're in your budget, but take a look at Kawasaki.com to see if the speedometer is shared by the B2A with the other models shown for the tach. You may be able to get them both for a good price. Good luck. Ed
- rstnick
- Thank you received: 377
I switched to Kawasaki Synthetic Oil recently. I'm finding it has affected my rpms in a good way. The engine revs a lot freer and smoother. I used to cruise around 80 KPH in 4th gear most of the time before, but am finding now with the synthetic oil, I will often find myself in 3rd gear at 80 KPH.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Dave Sloan
Z650B2 - Injected
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- Bluemeanie
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
- Thank you received: 2098
i wanna know what the difference is from a b2- b2a?? anyone know??
Gonna guess the "a" signifies model approved for sale in California (stricter emissions laws).
- cafekz750
I think you may want to think about re-jetting the carbs if you are running individual pod filters on the carbs. That is too much air for the stock jetting. This will effect how the bikes feels while riding at highway speeds.note for all purposes this bike is stock except the airbox is gone and K&N style filters are attached to carbs.....
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- rstnick
On my 650C2 the engine is reving at about 5000~6000 rpm in 5th at 100 KPH.
Update, after a ride last night.
My bike actually revs at 4800 rpm at 100 KPH, in 5th gear. Normally I would not ride in 5th at this low an rpm, I'd be in 4th at 100 KPH, unless it's really flat land or I'm going down hill.
I've found the Kawi Sythetic Oil has changed my riding rpms. Much more power and freer reving than with the old recycled cheep oil I was using before.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Bluemeanie
- Bluemeanie
