Funny shifter.
  • brawnyrebel
  • brawnyrebel's Avatar Topic Author
Funny shifter.
28 Jul 2007 12:00
#160311
Well it's actually not that funny at all. When i push my shifter down into first it stays there. I can pull it back into nutral but no second gear. I just had the motor out of the bike and turned every witch way but loose to paint it. What have i done and what should i be looking at? which cover am i going to have to pull
  • Frank
  • Frank's Avatar
Re: Funny shifter.
28 Jul 2007 12:04
#160314
it won't go into second if its not running.
  • The Milkman
  • The Milkman's Avatar
Re: Funny shifter.
28 Jul 2007 14:12
#160334
Usually, it won't go into second if it's not moving. This is normal, makes neutral a lot easier to find.
  • brawnyrebel
Re: Funny shifter.
28 Jul 2007 17:26
#160359
Thats good to know. Right now it functions as a two speed where the shifter is either down in first or up in neutral and makes no effort to return to its usual resting place. It functioned fine before i took the top end off of it. I did not remove any covers or change anything but the top end but i did drain it and turn it upside down to paint it.
  • Frank
  • Frank's Avatar
Re: Funny shifter.
28 Jul 2007 17:41
#160364
taking the top end off could not cause this. By what your sayin is the shifter stays down when shifted to 1st and stays up when shifted to neutral. Thats wierd could be a shift linage problem if you removed it to remove the engine from the frame.
  • Frank
  • Frank's Avatar
Re: Funny shifter.
28 Jul 2007 17:42
#160365
the model and year of your bike would help to.
  • brawnyrebel
Re: Funny shifter.
29 Jul 2007 07:42
#160491
It is a 76 900ltd. The only thing i took off was the shift lever. It did start the first try after having the top end and carbs apart though.
  • The Milkman
Re: Funny shifter.
29 Jul 2007 08:28
#160502
One of the guys with more experience and knowledge will be more help but, the spring in this picture may have come loose. Well that picture sucks, resizing made it unreadable,
Post edited by: The Milkman, at: 2007/07/29 11:38
  • The Milkman
Re: Funny shifter.
29 Jul 2007 08:36
#160504
It's thee spring in my crude box.:laugh: :laugh:
  • RetroRiceRocketRider
  • RetroRiceRocketRider's Avatar
  • ...bring in the machine that goes PING!
Re: Funny shifter.
29 Jul 2007 08:57
#160508
Did you re-install the shift lever in the exact same position on the shift shaft splines?
Before removing my shift lever, I took a razor blade (anything metal and sharp, like a dental pick, will work here) and scratched a small line across the lever and shift shaft so that there's no question as to refitting it in the proper position again.
Re-installing it in a diff than original position would probably only affect the angle the lever sits at, but then again it could possibly be causing it to rub somewhere - is there a chance that you have the shift lever pushed to far onto the shaft, and it's rubbing/binding on the engine cover? :huh:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
  • brawnyrebel
Re: Funny shifter.
29 Jul 2007 09:52
#160528
I don't think that rubbing is the issue. The spring is a viable option though. Is that behind the clutch cover ?
  • 76 LTD
  • 76 LTD's Avatar
Re: Funny shifter.
29 Jul 2007 11:43
#160538
I know a couple of guys who experienced something like this after the bike fell over on the left side and banged the shifter on the grond it knocked the linkage out of whack.had to pull the clutch and line the levers back up on the drum or something like that.
