What is typical on freeway
- aarons80kz650
- Virii
- I like cheese
- Thank you received: 1
That brings me at exactly 5k at 70mph in 5th. I really feel the powerband kick in around 3k and I can still feel it at 5k. Going from 70 to 100 feels like it would happen without my even realizing it. If I give her a nudge her on the freeway, she wakes up and I hold on.
How is your bike otherwise? Have you checked that you're where you need to be on your carbs and plugs? Maybe you're missing under load...? although I expect you'd probably notice that so *shrug*
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- aarons80kz650
Post edited by: aarons80kz650, at: 2007/07/27 00:32
- Virii
- I like cheese
I did my undergraduate in electromechanical engineering so gear-head, I'm certainly not...but I'm heading that way in a couple of weeks and what limited knowledge I have, I'd be happy to toss your way.
My mileage is ranging about upper 40's, lower 50's so I'd expect you're probably about right but I've got a timing light, home made manometer, compression gauge, etc that you're welcome to use while I'm in the area to check things out. Girlfriend has a sister in the area she wants to stop by to see.
I'm in Seattle and heading to Boston...oh damn, am I ready for this.....I don't know, don't ask.....
Regarding the plugs, if you look up "plug" and "chop" on most sites you'll find reference to running relatively clean plugs under load for a good distance (mile or two) and killing the engine. When I've done it, I've run Tess at around 6k, hard, on a nice straight for a couple of miles..hit the kill switch and pulled the plugs to see where they were. Then later, run it at idle for about 5 minutes and killed it again. Checked the plugs. See where they were. (I have a colourtune I used on my old XS650 which I love but most people don't have/know/trust/etc) which I think is a good judge of idle but the plugs will tell the tale...
I guess what my verbose rambling is getting at is...when did you change your plugs and what do they look like?
- aarons80kz650
Why pull the plugs hot? I have read this before, just wondering. I'm too tired to go out for a run now, its about 2:40am so I just pulled the plugs cold. I was suprised at what I saw. They were changed a few months ago when I started trying to get the bike running after sitting for aobut 3 years. Before cleaning the carbs. They have about 300 miles on them of varied riding, stop and go, highway, putting around the lake. left to right 1234
- Snakebyte
- Thank you received: 2
My friend by the time we get done with you you will have a bike that runs like a raped date and a wife that hates you...........r motorcycle.:evil: :whistle:
Well I can tell you from experience these things are a process to tune. I have a 77 650B. Before me going this site my plugs looked EXACTLY like yours, and yes you need to clean your carbs, set the floats, and rejet.
WG is probobly the best person to get info on carbs.
Do you experience any poping noise out the carbs? Can you idle for a long time without giving it throttle?
OHH yeh I would get rid of those resistor plugs if you have the caps on your wires. B7ES is a good non resistor plug.
- BSKZ650
- Thank you received: 14
Check the plug wires to make sure they are good, as stated you need to run the compression check and timing, also check the valves, just a full tune up then see what it runs like
77 ltd1000, current rider
76 kz900, just waiting
- wiredgeorge
Your plugs don't look horrible but you need to spend a couple bucks on tools and get over it... if you want to ride a 30 year old bike, you just have to do some maintenance. Buy the manometer and buy the compression gauge. A compression gauge is fairly inexpensive. Then buy the manual you need. A manometer, a compression gauge and a Clymer manual will go about $100 total. You need them to do basic tune up and maintenance.
Then tune the bike up. Stop using resistor spark plugs. Use regular gas. Clean your air filter. See the coil repowering article under wg's Tech Stuff Index on our website. I suspect there is nothing wrong with your bike or carbs a little attention wouldn't fix. As for the original question... the power break up at higher rpms. this is very likely an ignition problem issue; wires? caps? coils? You didn't mention if you had points/condensor or an electronic ignition but if you have points/condensors, get rid of them and get an electronic ignition or at least tune them. Oh yeah, buy a timing light and check the timing... ooops, tell the missus that it is my fault you spent over $100 on tools hehe
- Virii
- I like cheese
Less money, less time = happier wife. What to do?
I wouldn't know
but if I WERE to come up with something, it would be to get a couple bucks cash back at the store each time...maybe take a couple of twenties here and there from your paychecks before anybody notices and stow it away somewhere. Then put it into a prepaid credit card and make your purchases from there.
You have a good hiding place, right? for your purchases? Get out of bed when she's asleep (you've perfected the cuddle-rollover to get your arm out from under her, right?) and do your work. She'll probably not notice new parts or tools if you give them some grease and weather. You've had them for a while, right?
You know, just some thoughts....
- nads.com
- Thank you received: 20
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- aarons80kz650
4 still looks a little wet.
As for how long it will idle without gassing it? I let it idle after this test and it idled 3 minutes before I got board and killed it.
