Rubber cam end caps delaminating?
- BARNEYHYPHEN
23 Jul 2007 10:10
Took the valve cover off a couple of week ago to replace a seeping gasket and decided to replace the four rubbers semi circular cam end caps at the same time.
Got it all back together and no leaks for 900 miles. Rode to Indy on Friday and back to Nashville yesterday and on arrival back in Nashville noticed a weeping at one of the cap/plugs. The cap appears to be delaminating. The rubber appears to be coming away from the metal substructure?
Anyone else noticed this happen to their's? Thanks.
- mariozappa
Re: Rubber cam end caps delaminating?
23 Jul 2007 10:19
I put in new rubber end caps about 3000 miles ago on the 650 with no problems yet.
Next time you're in Indy, stop by and say hi.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- BARNEYHYPHEN
23 Jul 2007 13:14
I was in Greenwood most of the weekend. Where are you v/s Greenwood?
- tjettim
- 76 LTD
23 Jul 2007 16:22
I installed some aof APEs aluminum plugs and eliminated the problem of the old rubber .
- APE Jay
- mariozappa
24 Jul 2007 05:06
Greenwood is on the south side, I'm up on the north side of Indy about 30 mins from there.
Those APE cam plugs are NICE! Too bad they don't make em for the 650's.
1977 KZ650C1
- DrWhizBang
24 Jul 2007 09:30
mariozappa wrote:
Agreed.
Agreed.
KZ650C2 w/810CC in Saint John, NB
-- a sleeper, methinks.
- MDawnz1
24 Jul 2007 21:58
Yup , those APE ones are nice .....
If all you have are stock ones ,
try this ,
Put them in backwards / inside out ......
whatever you want to call it ,
with the outside lip/flange ,
on the inside.
They WILL NOT leak or seep oil.
Just make sure they DO NOT touch the camshaft ends,
it might take a little tweak with a small screwdriver to wedge them OUT .
Done deal ,I have made at least 50 Z1s leak free with this trick.
try this ,
on the inside.
1974 Z1a, still 903
- BARNEYHYPHEN
24 Jul 2007 22:35
Thanks everyone for the tips and suggestions.
