Clutch Free Play..Engaging at End of Lever Travel
- deathman68
23 Jul 2007 06:00
Hello all,
It's actually been a couple of years since actively posting on here, so it's good to be back (although it appears as if my status was lost with the "new" forum).
On my 1980 KZ1000, I'm experiencing an issue with my clutch whereby the clutch lever does not engage the clutch until it is almost completely released. Per my Clymer, I have adjusted the clutch cable and rod. The cable is properly lubed, and the clutch is new (actually replaced it b/c I was experiencing this problem and thought that maybe the friction disks were worn thin).
I can obviously turn the adjuster on the bars to get the clutch to engage sooner rather than later, but this violates the free play rule because it is putting constant tension on the cable. Is it possible that I am misinterpreting what it truly means to have clutch cable free play? I'm currently interpreting free play to only mean that I am removing nearly all slack from the cable using the rod and adjusters to achieve ~1/8".
Any thoughts on this subject would be greatly appreciated.
thanks,
Jeff
Post edited by: deathman68, at: 2007/07/23 09:01
thanks,
Jeff
- Bluemeanie
Re: Clutch Free Play..Engaging at End of Lever Travel
23 Jul 2007 06:08
My bike does the same thing, drives me nuts. I have new metal and friction plates in the wings. I put on a new clutch cable which helped a little bit, proper adjustment. It's just the way it is, my clutch has no slippage at all but I would really like it to grab a little closer to the grip. As you know, you can make it grab anywhere you want. So I'm just getting used to mine..
- markmeinteil
23 Jul 2007 08:57
Doesn't the KZ1000 have an adjustment nut on the clutch release rod on the left side cover as my 750 has?
- deathman68
23 Jul 2007 09:05
Yes it does. Adjusted per spec with no change. Also tried playing with it to get the desired result..still nothing.
- Kiwiz
24 Jul 2007 06:30
One question is whether your release mechanism is worm or ball and ramp. I have 1981 1000J which has ball and ramp. Following Clymer is 100% Wrong for this system which only deals with the more common worm type adjuster. Clymer does not mention that the ball and ramp is adjusted in the reverse manner
Try unscrewing the cover adjuster until it meets resistance and then screw it back in 1/4 turn. See if it works then. if all else fails pull the cover off and have a look at the adjuster type.
