- Thank you received: 2
ZeCross exhaust
- beardog63
- tjettim
Look through the forum,there are several
discussions on them.
- MkII
- Thank you received: 1
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
- beardog63
- Rickman
...and I'd like to know what I'll have to weld to make it hang on my LTD, but I guess that can wait until I can afford the pipes.
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- dutchz
- Thank you received: 4
1974 Kawasaki Z1
Stock front hub and rear axle.
- Jeff.Saunders
I've been talking with one customer about the jetting on a KZ - very similar to what you'd see when installing a 4-1.
www.z1enterprises.com
Z1 Ent on Facebook,
- Bluemeanie
- Thank you received: 14
- tjettim
- Thank you received: 2098
You have to take them off to change the oil.
Believe this is correct with regard to the X-pipe with crossing underneath the engine.
But the cross-over dual exhaust version from Z1E appears to allow access to the oil plug and filter without removing the exhaust system, with crossing in front of the engine.
Z1E Cross-Over Exhaust
Have no actual experience with either system.
- MkII
Phx,Az
- z1rick
- Thank you received: 5
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
