oil leak @clutch rod seal
- 402delray
21 Jul 2007 17:23
I have '82 KZ 1000J. has oil leak @clutch rod . Know problem but not cure. Replaced seal and noticed 2 grooves worn in rod . Reversed rod . good until it wore grooves in other end of rod . any help thanks ,Dave.
- tjettim
Re: oil leak @clutch rod seal
21 Jul 2007 19:15
If you are getting premature clutch shaft wear your clutch pusher may be worn out.In 81 on I believe it
is a needle bearing pusher.
- mattylight
22 Jul 2007 12:04
i've got an 80 kz750 with the same problem, i replaced the rod, but i'm afraid that its going to rub the notches again...i couldn't figure out what was rubbing, felt like something inside the transmission. it doesn't seem to be in the pushing module, the rod gets worn just behind the seal. any ideas anyone?
Post edited by: mattylight, at: 2007/07/22 15:06
