Stroking an Kz1000
- ricerocket
Stroking an Kz1000
20 Jul 2007 14:01
Being a Harley guy former.I was wondering when we wanted power we would bore our cylinders.When we wanted more we would stroke the engine.Can you stroke kaws?
- PLUMMEN
Re: Stroking an Kz1000
20 Jul 2007 15:13
well i suppose ya could stroke a cow if youre into that sort of thing!:blink:
:ohmy: :S :dry: :blush: :whistle: oh wait you mean a kawasaki!
there is no way i can think of doing it the way the crankshaft is pressed together with the rods.you might be able to do it to a 650 style motor where the rods actually bolt on the journalsB)
- ricerocket
20 Jul 2007 15:18
I see what you mean i think.So you cannot remove a rod from the crank is what you mean?
- PLUMMEN
20 Jul 2007 15:26
not without serious work and some fancy tools to press it back together ,you would also need some expensive one off pistons.ive put together quite a few stroker chevy bigblocks and a few smallblocks things get a lot more complicated when you start stroking versus boring lots of clearance issues to deal with top and bottemB)
- modprod
20 Jul 2007 16:12
ricerocket wrote:
Falicon has been doing these for quite awhile but get out your wallet. They also sell the required spacer plate. www.faliconcranks.com/cranks_price.html
- Duck
- e vica na i sau na ga
20 Jul 2007 17:15
modprod wrote:
For a "Harley Guy", $4K should be pocket change!
ricerocket wrote:Being a Harley guy former.I was wondering when we wanted power we would bore our cylinders.When we wanted more we would stroke the engine.Can you stroke kaws?
- tjettim
21 Jul 2007 06:22
Pretend it is a Harley.Get the stroker crank kit
from Falicon.A 1500 cc big block,now you have 1620cc.
Get a 5000 dollar Vortex head with the 47MM/38MM
valves and a set of 5.10 lift MTC cams.Put it in a Kosman frame with a 360 rear tire.Put a gas tank
on it of a 1969 Kawasaki Bushwacker 175 (the Sportster
tank came of a 175 Ranger) and custom paint and chrome
everything.Maybe dig up a Magnuson super charger and
just run 15 inch straight pipes.That should make the
magazines.
magazines.
