alternator rotor
- incognito0160
alternator rotor
03 Jan 2006 11:33
hey guys, i have a79 650 motor sitting here and i need to get the rotor off it. I don't have rear axle so that's out. Does anyone know the thread pitch of the bolt used to take it off?
Thanks
Thanks
- OnkelB
Re: alternator rotor
03 Jan 2006 12:27
16mm/1.50 metric pitch - a 650 steering stem top bolt will fit.
77 KZ 650 B1, 82 GPz 1100 B2.
- donthekawguy
03 Jan 2006 18:38
Also if you try the "bearing in the hole trick" make sure you use a big bearing or you will mes up your crank. Don't ask me how I figured out that one! :whistle:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- incognito0160
04 Jan 2006 10:12
thanks for the help guys. i have to go out and get that bolt now.
The bike is across the state so i don't have any of the bolts.
