turbo charging
- jus1975
- www.tripleaperformance.com
turbo charging
19 Jul 2007 23:57
who makes turbo kits for these kz's.
whats a good price
has anyone built there own kit.
whats a good price
- tjettim
Re: turbo charging
20 Jul 2007 09:40
Mr Turbo sells a Turbo kit for the KZ1000Js for
$3999.99.
$3999.99.
- Lorcan
- Speed Loony
Re: turbo charging
21 Jul 2007 12:04
MrTurbo do a good kit for the money.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
- tjettim
Re: turbo charging
21 Jul 2007 19:18
They have been around quite a while,I have never heard
anything bad about them.
- jus1975
- Lorcan
- Speed Loony
Re: turbo charging
22 Jul 2007 08:48
Usually a rather basic 38-40mm Mikuni or Keihin. The Mikuni HSR42 is the draw through carb of choice. Getting the others to run right is a "challenge".
760cc - 8.69@162mph
- jus1975
Re: turbo charging
22 Jul 2007 11:37
Are those the ones usually used on HD. Have anyone ever heard of Zenith carbs. I was told they are really good to use because of th simple high and low needles(no jets).
- tjettim
- jus1975
Re: turbo charging
24 Jul 2007 21:24
I dont understand how a single 42mm carb replaces 4 26 or 29mm(whatever size a KZ1k has) in a turbo application. And how well would a Lectron work in a turbo system.
- jus1975
- Lorcan
- Speed Loony
Re: turbo charging
28 Jul 2007 23:37
jus1975 wrote:
Only one cylinder fills at a time remember
760cc - 8.69@162mph
- tjettim
Re: turbo charging
29 Jul 2007 09:42
Draw through vs blow through.With a presserized
system, venturi velocity is not controlled by
engine draw vs venturi diameter but by turbine
size and speed.I am sure Turbocharger designers
have spent many an hour with their dynos etc. to
work out the calculations.
