offset 530 sprocket
- wallyworld
offset 530 sprocket
19 Jul 2007 20:31
my 630 chain has about had it[ starting to climb the sprocket teeth] I would like to change to 530 but I'll need an offset to clear my tire.I can't seem to find offsets anywhere.any ideas guys ,thanks ahead of time
- Rickfabio
Re: offset 530 sprocket
20 Jul 2007 03:17
Try the zzr1100c standard sprocket fitted backwards, worked like a charm on mine, had to take off 5mm on my hub to lign up so no frame and tyre rubbing, but it worked and its cheap compared to offset prices. Check if it fits your spline shaft....it's a 12t spline?
- StreetfighterKz
20 Jul 2007 04:33
Try
www.schnitzracing.com
www.kzzone.com
www.pingelonline.com
www.americanclassix.com
www.klasmo-bikes.de
, and
www.pmfronline.com
All those should have offset front sprockets. I personally ordered mine through Klasmo.
I don't think that the ZZR1100 (ZX-11) sprocket will work on the earlier engines just the J/GPz models.
Later, Doug
Post edited by: StreetfighterKz, at: 2007/07/20 07:34
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- wiredgeorge
20 Jul 2007 04:53
