New Guy...brings problems...
- mattylight
19 Jul 2007 06:59
hey everyone, i'm matt and i'm new here. i just picked up a 1980 KZ750 H, for a pretty much a song and dance. I've been reading a lot of posts on here and doing a lot of work to the bike to get it rideable...here's what I've got so far: i was told the bike has been bored over to nearly 800(i dont know how to confirm this) it has 4into1 exhaust and when i got it was running open throttle bodies, i have since added cone filters. the bike seems to run great now, except for one final problem: once it has warmed up, (after 10 or so minutes of riding) if it is turned off (or stalled...OOPS) it cannot be restarted, until it has cooled. the starter seems to turn over just like normal, all the lights work...any ideas? thanks!
matt
matt
- BSKZ650
Re: New Guy...brings problems...
19 Jul 2007 07:01
have you tried to use the choke to restart
77 ltd1000, current rider
76 kz900, just waiting
- ltdrider
19 Jul 2007 07:11
It might be your re-start technique. Do you twist the throttle when you hit the start button? It doesn't need gas to start when it's warm. If you give it gas, you could be flooding it.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- JMKZHI
Last edit: 03 Dec 2008 10:05 by JMKZHI.
- BARNEYHYPHEN
19 Jul 2007 09:19
All in mm's....(Pi (3.142) x R squared (radius of one piston x itself) x stroke x number of pistons) divided by 1000 = cc's.
- 76 LTD
19 Jul 2007 18:23
Coils or ignition could be breaking down when hot.could be in the carbs or starter circuit could be pulling enough juice to keep it from firing.
- kzluke750
19 Jul 2007 18:35
I vote for Valve clearances being the issue! No question they should be confirmed.
1980 750 LTD Stock
Motors run on electricity, engines run on fuel.
-Jerry Baxter
-Jerry Baxter
- mattylight
20 Jul 2007 02:55
alright, i will check the valve clearances today. i will also check the spark on the plugs after the bike is warm. i have tried choke, no choke, half choke...all on the warm starts and nothing. i'll get back with answers. thanks for all the feedback so far!
- mattylight
20 Jul 2007 15:23
alright, after reading the write up on valve clearances i realize that i am missing a few tools and things neccessary to measure valve clearances. but i rode the bike for about 20 minutes and had a lot of the symptoms of valve clearance issues. so if anyone has any pointers on this process for a new guy let me know. i will be buying the feeler gauge, and shim puller tool, as well as a valve cover gasket soon. then i plan to make the measurment, and order the shims later. which feeler gauge on Z1 is the best set to go with? and where do i get the kawasaki shim puller tool? thanks again for all the help!
- JR
20 Jul 2007 16:58
The good news is that the shims are under bucket so you should'nt need a shim puller tool. Bad news is that if you do need to change shims you have to remove the camshafts first and then lift the bucket.
