lost front sprocket nut
- djnubz
18 Jul 2007 14:49
I don't see them at z1, should I just get one from kawasaki?
Post edited by: djnubz, at: 2007/07/18 21:09
- donthekawguy
Re: lost front sprocket bolt
18 Jul 2007 16:52
Do you mean the nut?
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Sandy
- Fly High,Tony
Re: lost front sprocket nut
18 Jul 2007 20:57
List Your bike in Your signature,Bud,so We all know what bike You're referring to.Also,Someone close to You might have a spare nut that They'd part with.(that didn't sound right,lol)
Speaking from experience...if the nut came loose,then the locking washer in behind the nut has probably been fatigued,and IT is probably the cause of the nut letting go.The small tab on the washer that inserts into the hole in the countershaft sprocket may have snapped off,if there was any play in the nut.The lock washer is meant to have an edge bent away from the surface of the sprocket,over and locked against an edge of the nut(once the nut is tightened).If You've changed the sprocket,or just removed the assembly,then that bent section of the washer will weaken from stress,and when it lets go,then the nut WILL loosen,from direction of engine torque.
You're best off to put on a new lock washer when You do put it back together.
Jeff has them at Z1...not too sure on the nut though,and it also depends on Your bike.
1977 KZ1000 A-1
- inline4
19 Jul 2007 16:01
Jeff has the lock washer, but NOT the nut. He says he could track some down but it would take several days, then the time for shipping. I know this cause I just inquired about one.:ohmy:
Jim
Jim
- djnubz
20 Jul 2007 17:57
it's for my 1977 kz1000. I saw the lock washer but no nut. Anyone have one of these?
- Sandy
- Fly High,Tony
22 Jul 2007 13:43
djnubz wrote:
If You still need one,let Me know...I might have a spare one...
1977 KZ1000 A-1
