petcock/shotoff valve questions for kz750 ltd
  • k0pper
  • k0pper's Avatar Topic Author
17 Jul 2007 20:17
#157620
Anyone know if a petcock/shutoff valve off a 1983 kz750 ltd twin would fit an '80 kz750 ltd 4 cyl? based on pics they look the same and I wouldn't imagine functionality would be much different.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: petcock/shotoff valve questions for kz750 ltd
18 Jul 2007 04:18
#157665
k0pper... Welcome... don't you think this is more related to carb stuff than engine? Anyway, a petcock is a petcock... you have two types; vacuum and gravity and I suspect both the bikes you are asking about are vacuum actuated. If you measure the mount bolt offset, on your petcock, it will likely be 44mm. If so, www.z1enterprises.com sells a replacement Suzuki petcock that will fit.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
18 Jul 2007 05:25 - 03 Dec 2008 10:10
#157689
del
Last edit: 03 Dec 2008 10:10 by JMKZHI.
