Engine bearings???
  • burnout
  • burnout's Avatar Topic Author
Engine bearings???
14 Jul 2007 19:45
#156859
Anybody found a source for cam and main bearings for KZs??? I'm restomodding a '79 1000 and haven't been able to locate any. the parts guys at the bike shop I work at have run out of sources, too. let me know if you have any good sources.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Engine bearings???
15 Jul 2007 08:05
#156922
I believe the mains are plain bearings and the cam bearings are available through www.z1enterprises.com I believe. Contact them and ask them if they don't list them on their website.
  • modprod
  • modprod's Avatar
15 Jul 2007 17:17
#157002
Z/KZ have "roller bearing" cranks and they can be replaced by several crank builders Falicon in Florida is one, GRC is another and Gary Clark is another but there are more. Cams run in "plain" bearings in these heads and they are available from Z1E as previously mentioned.
  • burnout
16 Jul 2007 16:14
#157249
All of you guys are awesome!!! Thanks a lot!!!
