First Time in 14 Years
- MNKZ650Guy
14 Jul 2007 09:52
Hey Guys,
I picked up a KZ650 with 5600 miles. Poor girl has been a garage ornament since 1993. She still has the break-in schedule on the tach. I immediately removed the carbs before running because the throttle would not move, carb pistons were stuck.
So I cleaned up and put new accelerator pump rubber and O rings. Finnaly got it together last night. Fired it up.
1. Only runs on choke
2. 1&2 cylinder get hot while 3&4 get luke warm.
3. Has spark on 3&4.
4. Have reciept for major tune at 5200 miles/shims etc.
5. Next steps - Help!
- Mcdroid
- Gone Kwackers
Re: First Time in 14 Years
14 Jul 2007 10:12
Back to square one...pull the carbs and reclean, paying particular attention to the jets.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- jordan172005
14 Jul 2007 10:30
also if you haven't already I'd replace the plugs and check the points
- tjettim
16 Jul 2007 11:26
The Kawasaki's with accelerator pumps were
notorious for being lean on the pilot circuit.
Run a small wire through the pilots to clean
them,carb spray is not enough.Set the air screws
at 1 1/2 turns out to start,some model have little
caps pressed in you have to drill and pry out to
get at them,some have a plastic nob pressed on to
the screw only letting you get about 1/2 turn open,
remove the plastic piece for more adjustment.The
longer a bike sits,the harder the carbs are to clean.
The last bike I did would not run right untill I installed all new pilot jets.
- themachine
17 Jul 2007 03:12
don't forget to put your bike/location in your sig.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
