Aluminum Putty
- CoreyClough
- GPz550 Addiction
Aluminum Putty
13 Jul 2007 07:05
Recently, I've had the shifter pivot on my case break off, and oil will leak out through the shift shaft. The only cure for this is to replace the case. Both cases need to be matched, so I'd either replacet them or try a repair first.
Here's the before with the broken shift support piece:
www.superkleendirect.com/index.asp?PageA...n=VIEWPROD&ProdID=66
This stuff works great. :woohoo:
Here's the after-picture of my over-puttying after letting it sit overnight.
Word is after letting it set up, it can be machined almost like a metal.
Giving it a try, and I'll see if it's held oil in the engine overnight, otherwise I'll have a big mess.
Give it a try. It's worth the money spent.
'85 GPz550(ZX550-A2)
- RonKZ650
Re: Aluminum Putty
13 Jul 2007 07:12
The Devcon is good "epoxy". That's what it is really. I used it years ago and after dry you can sand it smooth and it sands and acts exactly like JB Weld which is also very good. They make this stuff all sound like it drys like metal, but it doesn't as it's still just a variation of epoxy. Works good for many things though. Good luck, what a strange thing to have break it seems like.
- OKC_Kent
Re: Aluminum Putty
13 Jul 2007 07:22
Isn't there supposed to be an oil seal or maybe an o-ring at that area?
Cashion, OK
78 KZ650 B2 85,000+ miles
- CoreyClough
- GPz550 Addiction
Re: Aluminum Putty
13 Jul 2007 07:39OKC_Kent,
The cover that bolts over that shift shaft has 2 seals on it. One for the shift shaft and the other for the crank shaft.
- hmondo
Re: Aluminum Putty
13 Jul 2007 09:44
Does anyone know how it stands up to heat? The reason I ask...is that I have an exhaust baffle that has broken on my KZP. Althought the exhaust is steel, I'm willing to try anything that will keep it from vibrating while riding. Any help is greatly appreciated!
1989 KZ1000 P-8 (Police)
1987 ZL1000
1986 Concours (Project Bike)
1987 ZL1000
- Virii
- I like cheese
Re: Aluminum Putty
13 Jul 2007 09:57
I've used JB Weld on exhaust before and never had a problem. In a pinch, you could consider using some exhaust bandage but it might be worthwhile to clean it really well and try some high temperature brazing as a temporary cure. You could easily get the proper equipment for around $30-40.
Tess: 1977 KZ650-C1. VM24, 97.5/15/3rd. Dyna-S. Stock exhaust, coil mod performed, BR7EIX.
Angel: 1982 GPz550. Stock. DR8EIX.
- Frank
Re: Aluminum Putty
13 Jul 2007 10:15
I do all my exahust welding with a flux core mig. If you turn the heat down at it lowest setting and the wire feed you can weld really thin steel if you do a series of many tacks.
- tjettim
Re: Aluminum Putty
13 Jul 2007 10:48
The glue will eventualy fail.Find a Heli-arc
shop that has alot of experience welding aluminum.
- BSKZ650
Re: Aluminum Putty
13 Jul 2007 12:06
I used some epoxy like that years ago on a intake manifold I broke at the race track, its still on and dosent leak
77 ltd1000, current rider
76 kz900, just waiting
- Jack
Re: Aluminum Putty
13 Jul 2007 13:18
Devcon is the epoxy used in ported cylinder heads to build up port floors or reinforce ports that have been extensively altered. So, yes it will work in high heat applications.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- tjettim
