1976 KZ 900 oil capacity
- BARNEYHYPHEN
12 Jul 2007 09:14
Is 4.20 Litres (including filter) the correct oil capacity for the captioned?
I always replace the filter when I change the oil but tend to just dump one US gallon (3.78L?) back in to refill and don't worry too much about the extra 0.40L.
Should I be topping of with an extra 0.4L or not to worry?
Thanks.
Thanks.
- tjettim
Re: 1976 KZ 900 oil capacity
12 Jul 2007 09:32
Four quarts is plenty.If you check the window,
sometimes a little too much.I think some oil
gets trapped in the back of the pan.
- PLUMMEN
12 Jul 2007 10:07
i go with 3-1/2 and check it from there;)
- Sandy
- Fly High,Tony
12 Jul 2007 22:53
3700cc's is what's called for,but YA...put in 3 liters/quarts...run it for a bit(1 minute should do it),and then after You've let the oil settle...check the sight glass to see where You're at.
1977 KZ1000 A-1
- wiredgeorge
13 Jul 2007 06:24
If you have 76 engine cases, the 3700cc is embossed up there near the filler neck and that is about 4 qts. If usually fill the thing to where the oil is between the lines on the sight glass then run the bike a bit and top it off as the oil settles down into the crankcase.
- BARNEYHYPHEN
