KZ650 timing with a dyna s ignition?
- jordan172005
10 Dec 2007 18:59 #184493
by jordan172005
Replied by jordan172005 on topic KZ650 timing with a dyna s ignition?
What it did was the exhaust and intake got caught together and bent I did set it to 36 after I heard the first one snap back. It's too late though I was so mad
Post edited by: jordan172005, at: 2007/12/10 22:00
- kzdev1360
- Thank you received: 2
11 Dec 2007 08:56 #184569
by kzdev1360
2006 Gsxr 1000
1976 Kz900 LTD
1977 Kz650 (720 motor, andrews cams)
Replied by kzdev1360 on topic KZ650 timing with a dyna s ignition?
yea when i built my first 650 engine i had no manual and i was just trying to figure it out on my own, and i ended up having the exhaust and the intake valves opening at the same time. Being nieve and not checking i just kept trying to start it, then i realized the valves were opening at the same time. After i got it together properly (at least i hoped) it ran better than it ever did. Damn i got lucky.
2006 Gsxr 1000
1976 Kz900 LTD
- rstnick
- Thank you received: 377
11 Dec 2007 12:06 #184582
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic KZ650 timing with a dyna s ignition?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- jordan172005
11 Dec 2007 18:28 #184632
by jordan172005
Thank you rstnick. I have been lining the ex line on the exhaust up with the head not the arrow... on the hyvo chain ones you had to line up the ex line fro exhaust cam and the in line on intake between 45 and 46... this is way different. I need to find new valves now
I'll still try it this way though for sure. Again thank you very much.
- jordan172005
12 Dec 2007 13:24 #184757
by jordan172005
Ok, I tried putting it in time that way and it worked perfect. It has no compression so it definitely needs new valves Thank you all for your help I know now how to put it in time
- Bluemeanie
- Thank you received: 14
13 Dec 2007 05:43 #184850
by Bluemeanie
Replied by Bluemeanie on topic KZ650 timing with a dyna s ignition?
I feel for ya jordan, twenty five years ago I bent a valve doing something similer to what happened to you. I removed head and found one bent valve. Went to local Kaw shop and mechanic installed new valve ($11) for free! I know you don't know what valve(s) are bent but found this on ebay, may help?
tinyurl.com/3ywtby
tinyurl.com/3ywtby
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
13 Dec 2007 07:21 #184865
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic KZ650 timing with a dyna s ignition?
Or you can come and get the complete cylinder head that you said you wanted and your problem will be solved.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
