welding cranks-Phx area
  • MkII
  • MkII's Avatar Topic Author
10 Jul 2007 08:22
#155915
looking for a contact of anyone who can skillfully weld up my z1 crank in the Phx valley area. any leads appreciated.
1977A1 current project: 1075, Web cams, VM29's Cavanaugh massaged head, Z1 crank
1979A3A Parked in 1986 left in shed
Phx,Az
  • tjettim
  • tjettim's Avatar
Re: welding cranks-Phx area
10 Jul 2007 09:11
#155923
I sent mine in to Falicon for welding and balancing.
My motor was much smoother afterward.
  • elseed
  • elseed's Avatar
10 Jul 2007 10:12
#155940
I sent mine to our friends at APE over in the earthquake/fire/flood/tsunami-prone state to the west (and bought a crapload of shiny things at the same time).
Z1?! Your username says MkII. :huh:
'75 Z1B with mods
  • MkII
10 Jul 2007 10:12
#155942
I'm aware of Falicon and APE...looking for local talent if poss to avoid freight which will cost more than the actual work but may have to go that route anyway.
Phx,Az
  • MkII
10 Jul 2007 10:20
#155944
right, 79 MkII was my honey I had to part with 20 years ago when I relocated to Phx. I had a 75 Z1B prior to that. I always wanted to get another KZ after getting back into bikes 13 years ago after turning 25 and affording the ins. premiums here.... found a decent 1977 1000A and going thru it soup to nuts.
Phx,Az
  • MkII
10 Jul 2007 10:21
#155945
Phx,Az
  • austin3119
  • austin3119's Avatar
10 Jul 2007 11:02
#155956
TJ at Eastside Performance is the local old kaw guy.
343 S Davis
Mesa, AZ 85210
(480) 649-4440
He's had his shop forever and really knows these bikes. Don't just call him though, take a ride over to his shop lots of immaculately restored Z's , KZ's , Enfields, an Indian and a Harley that makes like 260 horsepower or something insane like that. I'm sure he does the work, but if he doesn't he will know where to point you.
Make sure you check out the KZ900 he just did for his wife. That bike is amazing.
Good luck.
  • APE Jay
  • APE Jay's Avatar
10 Jul 2007 11:15
#155959
Be sure whoever you get to do it, has the rod to check and make sure it is not twisted before they weld it.
Jay
  • wiredgeorge
  • wiredgeorge's Avatar
10 Jul 2007 11:26
#155963
The rod in question is a 17mm drill blank - a nice, straight rod... If you can fit the rod in the 17mm holes in all four rods where the piston pins normally go, the crank will be a straight one. The holes are VERY tight and you may have to grease the rod up a tad. I think you can get the rods from McMaster-Carr or whatever that tool place is called. I think that is where I got mine. I also think that scientific folks call this "indexing the crank" but I might be mixed up on that fact...
  • MkII
11 Jul 2007 08:52
#156135
thanks for the info Austin...... so fit the 17mm rod thru the small end on all four con rods at the same time then that tells you there is no twist in the crank..makes sense. sounds like this local shop should be able to handle it, if not off to APE it goes.
Phx,Az
  • MkII
11 Jul 2007 08:53
#156136
Phx,Az
  • tjettim
  • tjettim's Avatar
11 Jul 2007 09:02
#156139
You can say that again.
