I want a external oil filter
- kawtoy
09 Jul 2007 18:52
Where could I find a external oil filter like the one in the pic? It would add oil capacity, would filter better than the internal filter and it would be soooo much easier to change.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- RetroRiceRocketRider
Re: I want a external oil filter
09 Jul 2007 18:59
K&N offers remote oil filter kits....I bought one for my 3.0L Toy 4x4 pick-em-up several years back.
Can't recall what I spent for it though. :huh:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- Snakebyte
10 Jul 2007 09:51
Boat place will have them. B+M sells them also.
Chevy blazers have them too 1996-2004
- fastestz1
10 Jul 2007 11:56
if you are thinking about running a remote oil filter
on a 900/1000 i would strongly advise against it,the 900/1000's do not make enough oil pressure to use one of these filters.
- 76 LTD
10 Jul 2007 15:53
I agree with fastest these bikes only make 2to3 psi oil pressure.the burning question on my mind is what kind of carb setup is that.
Post edited by: 76 LTD, at: 2007/07/10 18:55
- Frank
10 Jul 2007 18:03
it looks to be a twin, thus having 2 carbs
10 Jul 2007 18:42
kawtoy wrote:
Recalling the OEM oil "by-pass" design which allows oil to flow around a dirty-clogged-blocked filter so as to continue circulating throughout the engine, (unfiltered oil being better than no oil).
With this in mind, would want to assure the external filter also has a by-pass arrangement.
- 76 LTD
10 Jul 2007 18:43
Guess your right i thought it was a four.someone makes a kit for the SOHC hondas to convert to 2 44mm carbs.
- fastestz1
11 Jul 2007 04:02
kawtoy do you want this for a 2cyl or for your 1000?
- Jack
11 Jul 2007 12:00
I beg to differ here. We ran a remote filter on a dragbike for 2 seasons with no ill effects. Although I doubt it would pass tech now ,it did allow for a small amount more oil but we did it to have easy access to the filter for changes.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- fastestz1
11 Jul 2007 12:55
i hope im wrong about the low oil pressure,jack did you run with or without a factory filter?
- martijn
11 Jul 2007 13:12
that is a 750 twin. I'ts oilfilter is behind the left cilinder located..typical place
