I want a external oil filter
09 Jul 2007 18:52 #155789 by kawtoy
I want a external oil filter was created by kawtoy
Where could I find a external oil filter like the one in the pic? It would add oil capacity, would filter better than the internal filter and it would be soooo much easier to change.
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
  • RetroRiceRocketRider
  • ...bring in the machine that goes PING!
09 Jul 2007 18:59 #155791 by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic I want a external oil filter
K&N offers remote oil filter kits....I bought one for my 3.0L Toy 4x4 pick-em-up several years back.
Can't recall what I spent for it though. :huh:
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING :-/
10 Jul 2007 09:51 #155933 by Snakebyte
Replied by Snakebyte on topic I want a external oil filter
Boat place will have them. B+M sells them also.
Chevy blazers have them too 1996-2004
10 Jul 2007 11:56 #155971 by fastestz1
Replied by fastestz1 on topic I want a external oil filter
if you are thinking about running a remote oil filter
on a 900/1000 i would strongly advise against it,the 900/1000's do not make enough oil pressure to use one of these filters.
10 Jul 2007 15:53 #156009 by 76 LTD
Replied by 76 LTD on topic I want a external oil filter
I agree with fastest these bikes only make 2to3 psi oil pressure.the burning question on my mind is what kind of carb setup is that.
Post edited by: 76 LTD, at: 2007/07/10 18:55
10 Jul 2007 18:03 #156028 by Frank
Replied by Frank on topic I want a external oil filter
it looks to be a twin, thus having 2 carbs
10 Jul 2007 18:42 #156040 by Patton
Replied by Patton on topic I want a external oil filter
Recalling the OEM oil "by-pass" design which allows oil to flow around a dirty-clogged-blocked filter so as to continue circulating throughout the engine, (unfiltered oil being better than no oil).
With this in mind, would want to assure the external filter also has a by-pass arrangement. :)
10 Jul 2007 18:43 #156041 by 76 LTD
Guess your right i thought it was a four.someone makes a kit for the SOHC hondas to convert to 2 44mm carbs.
11 Jul 2007 04:02 #156080 by fastestz1
kawtoy do you want this for a 2cyl or for your 1000?
11 Jul 2007 12:00 #156167 by Jack
Replied by Jack on topic I want a external oil filter
I beg to differ here. We ran a remote filter on a dragbike for 2 seasons with no ill effects. Although I doubt it would pass tech now ,it did allow for a small amount more oil but we did it to have easy access to the filter for changes.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
11 Jul 2007 12:55 #156185 by fastestz1
i hope im wrong about the low oil pressure,jack did you run with or without a factory filter?
11 Jul 2007 13:12 #156193 by martijn
Replied by martijn on topic I want a external oil filter
that is a 750 twin. I'ts oilfilter is behind the left cilinder located..typical place
