Help. Yet another broken bolt
- brawnyrebel
08 Jul 2007 17:11
I have broken one of the small head bolts off( the ones at the outer end of the head). Does any one know of a good way to fix this without taking the head back off. Has any one ran one with one of these bolts snapped off?
- BSKZ650
Re: Help. Yet another broken bolt
08 Jul 2007 17:41
unless you can grab it with some vise grips, then no, you will need to pull the head, bummer:(
77 ltd1000, current rider
76 kz900, just waiting
- FloridaBiker
08 Jul 2007 17:45
I assume your bike is a KZ1000/1100?
If so, I fixed mine without pulling the head.
Pull the gas tank, drill it out, extract it, whatever.
Don't worry too much about damaging the threads.
If you do drill into the threads use a 7/16 USS (yes American threads) tap and bolt to repair.
Works great!!
Post edited by: FloridaBiker, at: 2007/07/08 20:48
Works great!!
- FloridaBiker
- FloridaBiker
08 Jul 2007 18:06
sorry for the duplicate post
Post edited by: FloridaBiker, at: 2007/07/09 18:36
- brawnyrebel
09 Jul 2007 03:53
FloridaBiker wrote:
Post edited by: brawnyrebel, at: 2007/07/09 06:54
Thanks. This is definitely worth a try.I assume your bike is a KZ1000/1100?
Works great!!<br><br>Post edited by: FloridaBiker, at: 2007/07/08 20:48
- wiredgeorge
09 Jul 2007 07:58
The bolt can be removed without removing the cylinder head. It just goes through a blind hole in the head and bolts to thread in the block. The 7/16" bolt trick isn't a good idea as 7/16" is SMALLER than the 6mm bolt and the thread you cut will be weak. Drill out the bolt first using a small bit; perhaps a 1/8" cobalt bit would be best. You can drill all the way through. Then try an EZ out on the bolt. DO NOT force because IF you break the EZ out you WILL have a problem. If the bolt comes out, replace with a 6mm bolt. If not, drill it out and use an insert to install in the thread after tapping the hole. You could use a 1/4" bolt or a 7mm bolt and just cut new thread using a tap.
- harm
- Tom
09 Jul 2007 09:05
Its not often someone can correct someone as wise as WG but 7/16(.437) is larger than 6mm(.236). Or did i miss something?
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- wiredgeorge
09 Jul 2007 10:50
You are correct, a 7/16" is larger than 6mm... a 1/4" bolt is also larger than a 6mm. In fact, the 7/16" is A LOT LARGER. I am not good at SAE bolt sizes... my mistake. I occassionally will recut the thread on a LONG 1/4" bolt... the ones used to hold the outer countershaft sprocket cover on as no 6mm bolts are usually available locally in that length.
- brawnyrebel
09 Jul 2007 14:42
Does it take a special long tap or will a normal one usually do? Also if any one has one of these bolts laying around i would greatly appreciate a measurement. I appreciate all the help guys.
- FloridaBiker
09 Jul 2007 15:38
Sorry guys.
It is a 1/4" bolt with a 7/16" head.
It is 2" inches in length, from my local hardware store.
And it is larger in diameter than the 6mm bolt that was there.
I used a standard length tap, from same hardware store.
Tape over your sparkplug hole.
I cleaned all the debris out of the newly threaded hole with a grease coated Q-Tip.
Post edited by: FloridaBiker, at: 2007/07/09 18:49
- brawnyrebel
09 Jul 2007 17:50
Thanks alot guys. I bought a tap and bolt and got her all fixed up. Now if i can stop breaking bolts i may get to ride it this year
